Polygons connecting to wrong vertices [Solved I think]
I have a model that loads into Hex just fine. I've even done some editing on it already just fine. But sometimes when I make an edit, a lot of the polys in the model have a corner that is suddenly connected to the wrong vertices elsewhere on the model. (Polys and vertices completely unrelated to the polys I'm editing.)
How can I fix this? I've tried loading it in blender and resaving but that doesn't help.
*edit*
I also just tried to do an average weld over the model before editing and that didn't work either
*edit 2*
I think I figured out why it's doing that. The model has some Ngons hidden in there. When I triangulated them, it was fine. Then when I did Boolean cuts, it created more Ngons so I need to remember to Triangulate after each edit to make sure it's all good :)
