Map Poser library to My Library or My Library\Runtime?
I started with DS and just bought PP2012 and my libraries are set up as !!My Library, !!Environment, etc. My only question is in Poser, how do I map the content folders for it? Do I map it the same way as in DS and set it to the main !!My Library, !!Environment etc folders, or do I map it to the \Runtime folder that's INSIDE the DS libraries (seeing as everything outside of \Runtime are DS materials and things anyways- or does Poser need anything in the \data folder?).
Post edited by Lissa_xyz on
Same as DS - you want the folder that holds the Runtime folder.
So the folder just above \Runtime (which would be !!My Library in my case). Thanks. :)
Map it the same way in Poser, to the folder CONTAINING the Runtime folder.
Poser doesn't need the Data folder EXCEPT for DSON Importer.
