My render is just black image
Hi,
I tried to search in forums cant see any. Below is my setting:
I render before, it was ok as second picture.
Why is it ok sometimes and not most of the time?
Where do i go wrong? lighting setting are the same.
Thanks in advance.
cheers
1010 x 869 - 1M
1913 x 924 - 775K
Check the log for errors - go to help>Troubleshooting>View log and scroll to the end, just after trying to render. I do wonder if having the render mode set to Cartoon may be part of the problem - only the default DAZ Studio shaders have support for the toon mode..
Render settings > Advanced > render engine > make sure 3Delight is selected. One time I selected scripted 3Delight my renders were black image.
Yes, thank you for pointing that out i will double check it next time.
But it is true sometime it is ok sometimes it is not.
Thank you for pointing out the cartoon :-) i did the mistake,
notice it after and render again.
i just bought LUXUS and have problem with setting
cant seem to find the luxrender.exe file.
Thank you all
LuxRender needs to be downloaded and installed separately - Luxus is a bridge between DAZ Studio and LuxRender that does a lot of the conversion work for you, but it isn't the renderer itself. http://www.luxrender.net/
ow ok. Got it. thanks
i really feel than 3delight and LUXUS rendering have their own moods and mind.
Perhaps depending on the lights :-). Now my LUXUS rendering black
(before was beautiful image render) and 3delight rendering so fast in seconds.
Touch wood i like it like that.
