In my content library I have a folder selected. In my scene I have a hair model with a new IRAY shader I made. I want to save this new hair iray material into the selected content folder. How do I do that?
It mighe need some manual navigation to get to the folder path that you want to save the item in. By default, the presets get saved in your personal Preset folder.
I figured it out. You have to do FILE---> SAVE AS MATERIAL PRESET while your hair, prop or whatever figure is selected. I have to manually navigate to the folder I want to save it.
Alternatively, click on the "+" button at the bottom of the Content Library tab and select "Material Preset". This has the advantage of not needing to remember a manual navigation sequence, since the preset goes into whichever content folder you're looking at. You can either use an existing folder, or create a new one if you want to have a separate folder for settings you've saved.
Save-->Material preset
