Changing location of downloaded resources
I'm not sure if I did something wrong when I downloaded and installed Daz 3D but when I download and install stuff with DAZ Install Manager it puts it on a hard drive I want to keep as clean as possible and not the hard drive I want it on, is there any way to move everything to the location I want it on?
Yes - in Install manager click the gear icon at top-right to open Settings, then go to the Installation tab. Click the + button to add a new location, give it a descriptive name, and click the ... button to select the folder. Having done that, click the button at the bottom of the Installation tab labelled Current and select your new location. Open Daz Studio, download the script from http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config_import/start (the download link is just above the block with the code) and drag the downloaded file into the DS Viewport. You should now be able to install to the new location, and DS should find the content installed there.
