They are, I think, the markers for soemthing like a Rigid Follow Node or a null that would not otherwise be visible. You should be able to select them and turn off Visible in Viewport in the Public beta version of DS, but not in the current release version.
I have two paintings in the room that are part of a group. If I hide the group that reticle goes away. The problem is that hiding it also hides the pictures! I'm not sure what to do? I don't want to have those reticles showing in the scene.
It's confusing that some groups have that reticle and other groups do not.
update, It turns out that all groups have those reticles. Then like you said i'll be able to hide them in the beta version, thanks!
They only show up if you use the preview render function in the viewport. They won't show up in the final render.
I'm not sure on what your workflow is, though, maybe you just use the preview render and make screenshots?.
A Group Node will hide/show its children in kind. A Null Node will not.
