Carrara Acacia Umbrella tree
StezzaStezza Posts: 8,165
edited July 2018 in Carrara Discussion
I'm trying to get this in the tree room
and best I can work out is this
any ideas on settings on how to get it to look like the top one?
thanks
654 x 521 - 47K
Post edited by Stezza on
    edited July 2018
    Can be frustrating.  One suggestion that could help would be to have another generation of branches in your upper tree area for density.  The ramified and hybrid tree options do not have the extra branches as default, you have to add them.  See here for some screenshots I posted to remind myself how to do it.
    https://www.daz3d.com/forums/discussion/comment/3574716/#Comment_3574716
    Another option is to model a branch with multiple leaves and then substitute this new branch for the leaves in the tree tabs.
    EDIT:  Also, you may want to chane the start and end angle of your branches in your top most generation of branches.  They appear too steep.
    Post edited by Diomede on
    edited July 2018
    Here is a quickie with default shaders and default leaves.
    EDIT - One setting that seems to have a big effect, after you set the tree shape to "Hybrid" in the experts tab, is to return to the tree shape tab and play with the "Ramified threshold" slider.  It does not seem to be straightforward.  Higher numbers do not always result in a more dense branch/leaf result (nor lower numbers).  May have to return and adjust after you choose your settings for each generation in the expert tab.  And you may want down gravity in tree shape as well.
    640 x 480 - 15K
    1818 x 1013 - 157K
    1872 x 1024 - 162K
    1893 x 1019 - 162K
    kk05 tree shape ramified threshold down for more dense question and tree shape controller.JPG
    1887 x 1036 - 156K
    edited July 2018
    After a couple more adjustments to the length/angles of the first generation of branches and applying a curve to the second.  Not great, but it is a starting point.
    See attached zip file.
    640 x 480 - 23K
    zip
    zip
    Hybrid acacia car zip.zip
    4K
    If you make the end angle of your gen 1 branches close to 90 (it's with respect to the parent branch), they'll be flatter. Below 90 they'll point up, above 90 and they'll point down.
    ooo thats the tree in zoo tycoon.
    makes giraff happy wen in their enclosure.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,371
    I made a mulga once, forget how no longer seem to have it
  • StezzaStezza Posts: 8,165
    thanks for all your inputs
    shall experiment today and see if I get something.. I shall post my results good or bad later in the day...
    in the meantime I'm looking at Dinoraul's trees over at the Rendo nursery.. there's nothing worthwhile here at DazShop cool
    in case I can't do a decent one I shall buy one!! eeeeek!
    edited July 2018
    There is a free tree program called Arbaro - you might give it a try
    https://sourceforge.net/projects/arbaro/
    I dont use Arbaro, so here are some alternatives
    https://alternativeto.net/software/arbaro/
  • DesertDudeDesertDude Posts: 1,238
    edited July 2018
    I took a stab at this, but first want to echo Diomede's awesome suggestions, especially creating a custom branch with leaves and substituting that for a "leaf". I also want to say thanks to TangoAlpha for the helpful hint. That, combined with Diomede's link above about Hybrid Trees brings the possibility of creating a tree trunk that "splits".
    Meanwhile I have been flailing around in the Plant Editor for the last hour and half or so like it's Peabody and Sherman's Wayback Machine...and got the results pictured below.
    It's important to note I duplicated the plant and rotated it and raised it up on the Z axis a bit...exposing the horrible roots of the raised tree, lol.
    Which then reminded me of another avenue for you: Years ago a longtime Carrara genius teased us with a product called...'Super Trees'(?) where he combined trees together. So, you may be able to create your tree in parts and still preserve the parts as procedural plants. Just a thought.
    Edited to add: I thought at the time those 'Super Trees' involved bones, and just tested, yes you can add bones to plants. Sorry if that is common knowledge, new to me.
    1303 x 808 - 124K
    1426 x 1074 - 83K
    1420 x 1068 - 71K
    1418 x 1068 - 91K
    1421 x 1078 - 76K
    1421 x 1070 - 96K
    1421 x 1077 - 98K
    1414 x 1070 - 96K
    790 x 592 - 96K
    Post edited by DesertDude on
    Ugh. Sorry, as usual I got a bit fooled. Adding bones to a plant automatically converts the plant to a vertex object? Apparently so...
    edited July 2018
    gave up on the tree room... couldn't get it to work the way I liked...
    so decided to model a tree trunk and add some hair to a semi duplicated displaced sphere.... surprise
    so far have ended up with this
    890 x 535 - 61K
    734 x 381 - 36K
    938 x 425 - 69K
    640 x 480 - 355K
    Do you know about this free software?  I have downloaded it, but not tried it yet.  Am going to be creating some steppe/tundra vegetation that I can't find anywhere after failing at making decent billboard type leaves, flowers, etc.  They have a texture tool and a mapscape as well.
    http://www.evolved-software.com/treeit/treeit
    indecision Silene
  • HeadwaxHeadwax Posts: 10,019
    that's wonderful Stezza, much better than the tree room!
    Yes, that looks great!!
    Well done, Stezza!
  • 0oseven0oseven Posts: 626
    indecision Silene
    Thanks for this link - looks very nice
    indecision Silene
    Someone had posted about it in free software that makes life easier. If you end up trying it, can you post how well it works some time?
    Stezza... I wonder if it's possible to use the curl tool to make the hair on the branches bend in a loop?  I like the lushness that the hair texture gives your tree. Hair is so versatile!  yes Silene
    and did you try gravity on the branches in tree room?
    yep...
    I could get nothing to work that I liked...
    I'll probably end up getting the dinoraul tree when/if it comes on sale
    SileneUK said:
    indecision Silene
    Thanks Silene..
    I tried the treeit .. it does have an acacia tree but I couldn't get the leaves looking good in Carrara..
    with the hair I used all the frizzes, curls, length ect ...
    Dinoraul has a scheffera like mine in my front yard, I bought his, I don't know if he has an acacia.
    The scheffera has umbrella arranged  like broad leaves, quite a different plant.
    Yep, he has an umbrella acacia and other cool stuff.
