Is the library index editable?
reko34reko34 Posts: 94
edited December 1969 in Poser Discussion
In poser 2010 it's possible to add more than one runtime directory to the library. But I don't find any button to remove them. Now one runtime itself no longer exist. And I want to change the name of another because longer name makes the refresh button more to the right side and I don't want to drag the window wider. But the index doesn't change with the directory so I have to add it once again and leave an empty index.
  • WandWWandW Posts: 2,840
    I'm not at a Poser machine right now, but the Runtime list is in LibraryPrefs.xml which, in Windows, is in the User App Data under Roaming\PoserPro\8, IIRC. It can be edited with a text editor. (make a backup copy first) You can change the order of the runtime list this way, too.....
  • reko34reko34 Posts: 94
    Thank you! Problem solved.
    For future reference, in PP2012 you get the delete key if you select the specific library next to Show Library: with the arrow. You won't get a delete key if it's set to All. It could be the same in 2010.
    916 x 156 - 36K
