Genesis: Duplicate Formulas Found?!
I have Genesis to automatically load when I start up Daz Studio 4.6 Pro. Whenever I do, I get this error message:
DUPLICATE FORMULAS FOUND
Duplicate formulas found in files. Make sure the Content is properly installed. See the log file for more details
Even if I delete Genesis from the scene and load up manually, I get the same error message. Genesis itself works fine, I can still use it. But I get this error message whenever I load it. Don't know why. It SHOULD be properly installed already so I don't what I did to get this error message. Can anybody help me get rid of it?
And I've tried to look for the log file to see if I spot something wrong, but I don't know where to find it.
I'd appreciate any help please
After loading Genesis and getting the error, go to Help > Troubleshooting > View Log. Scroll to the bottom and see if it tells you the offending morphs.
Thanks, Vaskania. Did that. Nothing but a confusing mess.
I looked around and saw Richard's FAQ with a possible fix. Gonna try that.
Just note that duplicate id is not the same as duplicate formula, if that's what you're referring to.
You can copy/paste the bottom of the log file after getting the error and I can look at it if you want.
It's very long so I just cut out a short segment of it. If you need/want more, I'll give you more. :)
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Expression Morphs Expansion/PHMFlirtingMasculineR.dsf#PHMFlirtingMasculineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Aiko 5/MCMAiko5HdFlirtingMasculineR.dsf
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Expression Morphs Expansion/PHMFlirtingMasculineL.dsf#PHMFlirtingMasculineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Aiko 5/MCMAiko5HdFlirtingMasculineL.dsf
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Expression Morphs Expansion/PHMFlirtingFeminineR.dsf#PHMFlirtingFeminineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Aiko 5/MCMAiko5HdFlirtingFeminineR.dsf
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Expression Morphs Expansion/PHMFlirtingFeminineL.dsf#PHMFlirtingFeminineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Aiko 5/MCMAiko5HdFlirtingFeminineL.dsf
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Expression Morphs Expansion/PHMFlirtingMasculineR.dsf#PHMFlirtingMasculineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Aiko 5/MCMAiko5FlirtingMasculineR.dsf
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Expression Morphs Expansion/PHMFlirtingMasculineL.dsf#PHMFlirtingMasculineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Aiko 5/MCMAiko5FlirtingMasculineL.dsf
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Expression Morphs Expansion/PHMFlirtingFeminineR.dsf#PHMFlirtingFeminineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Aiko 5/MCMAiko5FlirtingFeminineR.dsf
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Expression Morphs Expansion/PHMFlirtingFeminineL.dsf#PHMFlirtingFeminineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Aiko 5/MCMAiko5FlirtingFeminineL.dsf
File loaded in 0 min 9.9 sec.
Loaded file: Genesis.duf
Loaded Morph Deltas in 0 min 0.0 sec.
Loaded file: Enable Auto Correction.dsf
These are all warnings, not errors, but they mostly refer to Aiko 5. You may need to reinstall A5 to get rid of them.
I think they are the correction morphs, installed with A5, that adjust the mesh so that the Genesis Evolution Expressions work nicely with A5. If you don't have the expression morphs (which were bonus content when the Evolution morphs were first released) then there's nothing for the correction morphs to connect to and you get that warning: it's harmless and can be ignored.
Thanks Richard, very useful information.
Thanks, Richard. I don't have that expression pack. Going to have to rectify that.
And thanks, JimmyC and Vaskania for the help. :)
