Loading a Scene Changes preset morphs.
Every time I load a scene all of my genesis actors have there morphs re-mixed.
Sometimes I'll load a file and ALL the universal Vicky morphs are maxed. the preteens/Julie morphs are mixed and matched.
This has GOT to stop. I spent hours making my actors just right, and I don't remember my settings I used for each one obviously.
Can somebody help me please?
Are these older DSA type Files? I've seen it happen with some I've brought in from DS3.
I dont know what DSA and DS3 is. How do you check that?
This is what happens when I reboot Daz
You have Saved a Figure that over wrote your Genesis file. Just install the Genesis content again and it will be fixed. Tip: Never save a Genesis figure without adding to the name of the file.
Thanks. But how did I do that? Your are very vague in your responses. I don't know how I did that. Also how do I reinstall that stuff?
You have to remember this is the "New Users Help Forum"
Most of us dont know these things.
Ah, I was thinking you were advanced enough to know how the saved figure was done, I should never assume. I'm not sure what you were doing to save a Morphed Genesis over the old genesis so I can not help with that.
But to Fix the Genesis so it loads clean again it depends on how you Installed the Genesis Starter Essentials. Did you use DIM or did you install yourself?
I downloaded the package from my "My products page" and installed it from there. Dose that help?
I might add I been using Daz for 90 days with zero training so the abbreviations and technical terminology people use are completely foreign to me.
I did use this once, because it prompted me to save the figure before I can save my d-forms I used.
Is that what did it?
Very possible If you did not change the Asset name at save. To fix this just use your Genesis Starter Essentials and Re-install. It will only over write the default files and not hurt anything you have saved or added.
I'll try that. Thanks for your help.
