Where can Bryce content be installed?
Sfariah D
Where can Bryce content be installed? Does it have to be in the Program Files directory of Windows? if so why?
Miss Bad Wolf - some Bryce Content can be installed where you later find it, even on a memory stick. There are a few items that need to be in a very specific folder under the Bryce main folder. You find all relevant information in this PDF document. https://horo.ch/docs/mine/pdf/BryceContent_v4.pdf
I have none of my Bryce content installed in the Program files directory of Windows 7. Bryce and all it's content are not even installed on my C drive.
Horo's great guide covers your question in depth and I often refer back to it when I forget what *needs* to go where.
That said, the so-called 'big idea' goes (roughly):
- The Bryce *program* folder (with the main Bryce program (exe) and supporting program elements) can be located as a folder/collection anywhere you choose (as per Chohole's comment).
- Certain kinds of Bryce *content* must be in/under that same program installation folder.
- Other Bryce *content* can be located anywhere you choose (and can 'browse' to).
again, Horo's pdf file covers the various details in wonderful depth and clarity.
Good luck!,
--ms
Let's say I want to install my .obp files from Bryce 5, 5.5, and 6 into my Bryce 7 Create Library. Do I extract the files and then drag and drop them into the proper folder? I have several packages made for the earlier versions of Bryce, and I wish to use them in Bryce 7.1 Pro.
Mage 13X13 - you can select all in a particular library, export them and import them in the other Bryce version. You can also just copy the obp files into the new location.
