Genesis Fantasy Wrap doesn't wrap.
I've got the Fantasy Wrap dress for Genesis, but it cannot seem to cope with anything other than a straight up pose with the legs together. What I often want is to drape the front across a leg that is moved forward, yet none of the adjustments are any use for that. There are only 6 morphs available, none of which seem to affect the tails of the dress significantly. The product image in the shop shows the tails blowing in the wind, but I can't achieve anything like that. There are a couple of 'wind' morphs, but they (weirdly) only affect the top of the dress. I'm attaching and image of a render where I would like to morph the dress over the front leg. Here, only a very slight adjustment seems to be needed over the left leg, but nothing seems to do it.
If you select different parts of the wrap you can adjust them. In this pic I applied a mesh smoother to avoid the wrap cutting through her thigh. I also selected the pelvis and found sliders for twist bend and side to side. If you expand the figure tree further, you will find adjustments for front and back.
Thanks. That's fiddly, and it's easy to distort the clothing, but it does seem to work.
