Not So Fast! Interactive Game ~~ DONE~~Read The Moves!
![Novica](https://delorean.daz3d.com/forums/uploads/userpics/362/n63LNSMEOCCGK.png)
What is Not So Fast?
The Not So Fast! (NSF) contest is a forum-based game with good-natured interaction between participants resulting in a list of products each person must render.
For the game, there are Not So Fast moves done with, to, and /or between the participants. Have fun watching the artists manipulate, plot, and scheme to manuver products onto the final render list of each person. The six items a person starts with (two sets, three props, and a character) definitely will NOT be what they have to render at the end of the game!
The goal is simple. CREATE MISCHIEF. The gameplayers are NOT here to be cooperative! Or...are they?
They're playing for laughs and to see who can create the best "Not So Fast!" moves which leave other artists rendering funky combinations. The motto of the game is, " If you can mess with someone, do it." Strategy reigns supreme here, timing is everything. Other people DO have moves to get another player out of a bind- but will they use them? They might if the culprit has pulled a NSF move on them and they want to give some payback by helping out another recipient. You never know!
Basic Rules: To qualify for the prize gift cards, participants follow these guidelines. Posts will have the current tally of where they stand and are updated by the participants, it's very easy to immediately see what they've done AS THE GAME MOVES ALONG!
1. Each artist MUST make 10 "NSF" (Not So Fast!) moves in the game. A NSF action is added to your total when you initiate an action, not when you are the recipient. You can't just exist in the game, you have to PLAY! You are allowed up to 20 moves during the 4 day period. (Your post will show which moves you've already made. There's a standard format.)
2. You may not reverse a NSF action by using the same NSF action or repeating the action. (Someone forces you to swap with them, you can't force them to swap that product back to you. See 5)
3. Each game player must make moves involving a minimum of 6 different players. (Moves which involve two other people, and that would count for two people.)
4. Each player must use at least 4 of the 7 NSF moves. This prevents a player from using the same gameplay over and over. (Your post will also show this.)
5. Once an item has been taken OR swapped from a player, they can not get it back from the player who took or swapped it in that same reverse move. (Think strategy here!)
Communication During Gameplay:
6. Conspiracy and giving suggestions of what can / should be done TO OTHER participants is encouraged- it's time to "start throwing people under the bus." However- participants are limited to suggesting ONE NSF move. They can NOT map out two or more advance strategies or even hint at them.
7. The person on the receiving end (of a conspiracy being discussed against them) is allowed try to influence the outcome by pointing out BETTER MOVES AGAINST OTHER PLAYERS. They can not discuss themself AT ALL.
8. Players can not ask for help regarding their current situation, with the exception of the NSF #5 of a mutual swap.
9. All collaboration is done on this official thread. No PMing, emailing, smoke-signaling, Morse Code...you get the idea. The chitchat is out in the open for everyone to enjoy. Well, everyone except the player on the receiving end. It will be fun to watch alliances form and shift. The person you think has your back, just stuck you with a slimy worm, a worn toilet seat, or a lollipop.
10. A sponsor is regarded the same as a player- when they announce a NSF move, it is official. They will be using NSFs #4, #5 and #7 The same communication rules which can be applied, apply. (Discussing only one move, no behind the scenes collaboration.)
The NSF (Not So Fast!) Moves
Here are the NSF moves the players will make: (Remember-players must use 4 out of 7 and get a total of 20 moves) They are designed so even if a player is not online, the game continues without them. Their list of products in their possession will change even if they are not participating at the time. Players can not make moves with other players (such as swaps) unless they possess both items.
1. "I'll Swap With List" One time use during the entire game: Swap out one item with one from the list. The TYPE of item must be the same (a prop for a prop etc.)
2. "We're Swapping Says Me" Make another contestant swap products with you. Both people must own the same things and they must be the same TYPE. (a prop for a prop etc) This is a harder one, both items must be in their possession at the time.
3. "We Agree To Swap" One time use by a player during the entire game: Two contestants AGREE to swap products. DIscussion is allowed but NOT strategizing future moves. (See Communication rules.) In other words, you can discuss swapping one item, but not strategizing why you're doing it or what you plan to do after the swap.
4. "You and You Swap." Force two other players to swap items. YOU decide what they swap. Again they must be the same TYPE. (prop for a prop) Players must own both items and have them in their possession.
5. "Say Bye And Hi" Tell someone which product to give up to the list, and which one to take from it. The TYPE of item must be the same (a prop for a prop.)
6. "I'll Take That, Thanks." Steal an item from another contestant and decide what they take from the list. The TYPE of item must be the same. (getting the hang of it?)
You must then send one of your other items (SAME TYPE) to the list as now you have too many.
NO LONGER AN OPTION, DELAYS THE GAME
7. "You're A Thief" Tell another contestant (you chose) they MUST steal a specific item (they own) from another contestant. (you chose.) YOU'RE DONE.
The person that takes the item: (gets to chose)
a. Must give up the same type item (a prop if they had to steal a prop) to the list because they can only have 3 props, 2 sets, and 1 character. They may NOT give up the item they had to take.
b. The MINUTE they post the item they are giving up, it is available, whether Novica has had time to get it to the list or not. First come first served, but note it does count as a NSF (#3 above) whether it is on the list or not.
c. Tells the person they stole from which item from the list will replace it. And of course, it must be the same TYPE of item.
NEW!
8. "Fetch It For Me, Thanks!" Combining two moves, #5 Say Bye And Hi- and #2 We're Swapping Says Me. The person goes and gets an item you also own, and they give it to you when they get back.
First, make sure the product you have in your possession that you are swapping later with them, THEY OWN. (A) (This is the We're Swapping Says Me part.)
Tell someone what product they are giving up. CAN NOT BE A CHARACTER.
Tell them what item is replacing it. (B) (Be sure you OWN IT. They are bringing it back over to you.)
Take it (B) (must be the one they fetched) and give them an item (A the one you checked to see if they own it.) Must be a prop or a set. Must be the same type item
9. "Fetch Now You Two Swap Combining two moves, #5 Say Bye and Hi with #4 You And You Swap
This NSF move is when one out of two other players (NOT YOU) HAS IN THEIR POSSESSION an item both players own. (Item A)
The one who does NOT have an item in their possession owned by both players, you tell what product they are giving up.
Then you take an item from the main list that BOTH players own for that person. (B)
Then you tell them to swap the item the first person has (A, which they both own) and the new item (B) just brought in from the main list.
Oh, one more thing... (this does NOT count as a NSF action)
"The Old Hagrad" Hagrad makes the Old Maid look absolutely adorable. Send this woman on her way because when the game ends, if she's in your possession you automatically have to add another product (VOTED ON BY THE PARTICIPANTS) to your render.
Thinking about holding on to Old Hagred until the last minute and sticking it to someone? Nah, that's too predictable.
a. Once you receive Old Hagred, you must pass her along before you can do a NSF.
b. If it has been longer than 6 hours since you received the old gal, she will be moved along for you. (You put the time in the post when you give her to someone) SHE IS PUT ON HOLD AFTER 6 HOURS (by any participant who is online) AND YOU LOSE THE RIGHT TO PASS HER ALONG. The first participant to call the time on it, gets to look at the list of people (which is in EVERY post with Hagred) who have yet to receive her that round, and pick someone to send her to. Don't miss your opportunity to choose- send her within 6 hours!
c. Once a player receives Old Hagred, they can NOT get her again untill ALL players have had her at least once. After everyone has had Hagred, it starts over again, everyone gets her a second time before she can make the rounds a third time. Or more. Hagred should get her broom motorized, she's going to be visiting a lot of players!
Novica will launch the first one and show you how to do the post.
Observers are asked to refrain from entering the melee as the thread could easily get cumbersome and make it harder for the participants to scroll through and find the latest relevant status of other players. So please watch but do not post. This is a very, very different interactive approach to a contest, it's really a game in action. We need to help the participants keep track of things and also eliminate the possibility of posts which may violate the rules. (You may see a great strategy and want to address several moves, but that's not allowed. We also want to let the participants figure it out for themselves.)
Please do not point out infractions. Let the players handle it. Appreciate it!
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/34/cf451e7f2ebed141fc87cb766b565e.png)
THIS THREAD IS NOT OPEN FOR POSTS. IT REQUIRES A LOT OF SETTING UP AND THEN WILL ONLY BE FOR THE INTERACTIVE GAME PLAYERS. THANKS!
Link to the final renders goes here.
Deciding How To Get Credit for a NSF and for Interacting with Other Players:
How to decide if you get credit for a NSF and interacting with people is important. You must have interactions with at least 6 different people and use at least 4 different NSFs.
The rule is simple. If you didn't START the NSF gameplay, you don't claim it. You don't claim the NSF move, you don't claim the interaction with a person or people in the move.
Example: Novica tells nonesuch00 "Hey, you look bored. Not So Fast! #7, You're a thief... you must steal that Kangaroo from jakiblue. Then tell her what to get from Now Available to replace it. And you have to give up a character (the same type item nonesuch00 just had to steal) since now you have too many."
In that example, Novica gets credit for NSF#7 and credit for interactions with nonesuch00 and jakiblue. They get ziltch, nada, zero.
If barbult and IceDragonArt chitchat and agree to do a swap, they can both claim the interaction or decide who takes it. The interaction counts as two people (both claim themselves and each other.
The game is now live. Scroll down and see who currently owns what, and watch the timeline for a summary of the action. The posts will be more entertaining, however!
The Old Hagrad
(An image of Old Hagrad)
Players insert Old Hagrad's picture, then copy / paste (again, do NOT quote) the statements. They then add to the statement sequence and note the person they are sending her to in the YES section of ownership.
Then they add the date and time- DAZ TIME. The date and time sent is important! When the forum switches to another day, the time is erased over by our avatars and only the date shows.
Once everyone has had her once, all the yes comments will be removed and we start over again. Novica will do the first post of Hagrad, and you'll see how to do it.
Participants are asked to keep an eye out and make sure the YES gets noted.
Example, the sequence statements: (THIS IS JUST AN EXAMPLE)
1. August 13th 4:30 pm Novica sent Old Hagrad to xmasrose.
2. August 13th 10:30pm Barbult here! 6 hours and xmasrose has not responded. You snooze you lose. I'm claiming Old Hagrad and sending to RGCincy. (barbult gets credit for owning her, see below.) Hey RGcincy, I think she's your type.
3. August 13th 10:32pm RGcincy here. Appreciate that but I don't think so. I'm sending her to my good buddy IceDragonArt.(who gets credit for having her.)
4. August 14th 4:32am jakiblue here telling everyone to back off, she's mine. IceDragonArt was probably doing promos. I'm sending her to..... (jakiblue gets credit for having her.
Anyone who gets her, takes her, and / or passes her on is considered an owner.
People who have had Hagrad so far: (this goes back to none after everyone has had her, and we start over again)
3dcheapskate barbult YES dreamfarmer IceDragonArt YES jakiblue YES kismet
nonesuch00 Novica YES RGcincy YES Saphirewild Wonderland xmasrose YES
Who Started With What This is what the characters had when gameplay started. They didn't get to choose, there were guidelines as to specific pages/ choose from the top of a given page. Go to the NEXT POST to see what has changed!
3dcheapskate
Set 1: The Alcove Set 2: Summer Gazebo
Props: Steam BIke Pro (Pile of Luggage) Technophilia Arcane: Star Scope (Scope)
Mortuorum Sacris (Coffin Lid)
Character: Warrior Maiden Tanwen (V4)
barbult
Set 1: DM's Anardhaus Set 2: Shoot First Corner
Props: Laundry Day Mega Set (Empty Dryer Closeline) Wine Me (Corkscrew)
Vintage Boxing Accessories (Speed Bag)
Character: Yasuo for Lee 6
dreamfarmer
Set 1: Fantasy Tavern Set 2: DM's Cave of Secrets
Props: Sweet Tempation (Cake 1 W/ Sauce) Dreams of the Past (Centerpieces)
Monster Skulls HD (Cyclops Skull)
Character: FWSA Tiami (Callie 6)
IceDragonArt
Set 1: Dungeon Hall Set 2: Aeridian Interstellar Throne Room
Props: Black Market Blade Silent Death (Gen8) (Twisted Blades) Gothic Bedroom (Bed)
Kick Scooter (Scooter)
Character: CC Lily
jakiblue
Set 1: Forgotten Tunnel Entrance Old West Bath House
Props: Haunted Toys (ScareyBear) Lemonade Stand (The Stand)
Aslan Statues (Gargoyle)
Character: Aibell (Gen3F)
Kismet2012
Set 1: Collective3d Portrait Vignettes Old West 2 Collective3d Portrait Vignettes Old West 3
Props: School Lunch Props (Closed Lunch Bag) Make A Wish Props (Scepter)
Christmas Cookies (Mistletoe Cookie)
Character: Zoey for Victoria 5
LaPetiteVerita
Set 1: Industrial Storage Unit Interior Medieval Castle Tower Interior
Props: Public Indoor Pool (Lifesaver) Iray Ghost Light Kit 2 (Flashlight)
Crystal Vases (Twisty Vase)
Character: FWSA Pepper HD (Genevieve 7)
Nonesuch00
Set 1: Patio Dining Set 2: Versatile Terrain
Props: Fantasy Scythes (Classic Farmer Scythe) Geisha Prop Collection (4 Asian Inspired Fans)
Janitor Gear (Push Broom)
Character: Sakura 8
Novica
Set 1: The Ministry Set 2: i13 Foxy Lounge
Props: Aguja Undersea Environment (Kelp) Horse Drawn Carriage for Daz Horse 2 (Carriage)
Pentonville Cell (Toilet)
Character: BD Aspen (V8)
RGcincy
Set 1: Parkside Head Interior Set 2: Sci-fi Cockpit Interior
Props: Golf Course Props (Cart) New Colony Props (Module 3e)
Porta Potty (Potty)
Character: FW Laverne HD (Monique 8)
Saphirewild
Set 1: A Curious Hallway Set 2: Abandoned Gas Station
Props: RW Letters and More (Letter Q) Steam Bike Pro (3dcheapskate already had)
Ace of Spades Jack (Backpack)
Character: RDNA Sluggians
Stormlyght
Set 1: GIS Nova Set 2: Winterblack Tower
Props: SY Rigged Waterfalls Iray (Waterfall) Symphonic Sounds Poses/Props (Amp)
Z Deadly Weapons (Silver Gun)
Character: Keiko 6
Wonderland
Set 1: Collective3d Portrait Vignettes Old West 3 Set 2: DM's Dark Shrine
Props: Jeweled Excellence Earrings 2 (Gen2/3/8F) (Earring) Cyber Wings (Wings)
BBQ Grill Collection (Grill)
Character: Monique 7
xmasrose
Set 1: Tangien Portico Set 2 Tree and Swing
Props: Everyday Stationary (Diary Closed/Open) The Werks Mega Prop Pack (Lollipop)
Vintage Luggage (Briefcase)
Character: Star 2.0
CURRENT STANDINGS: Check TIMELINE. There will be a few minutes lag.
Changes to what players had in their possession are marked in red.
The next post down starts the Timeline- it will track for you the latest moves by the gameplayers!
3dcheapskate
Set 1: A Curious Hallway Set 2: Echoes of Andromeda
Props: Regenerator (Prop) Thursdays Child- Deaddy Bear (Bear)
Playtime (Hobby Horse)
barbult
Set 1: The Cage Set 2: Old Country Farmhouse
Props: Kick Scooter Signs of Protest (Sign Left Hand) Lemonade Stand (The Stand)
Character: Muck
dreamfarmer
Set 1: aMAZEing Journey Around The World Set 2: Sun Hall
Props: Props: Fun In The Sun (Lounge Chair) Everyday Groceries (Toilet Paper)
Laundry Day Mega Set (Prop: Empty Dryer)
Character: Charlotte 8
IceDragonArt HAS OLD HAGRED Can be moved NOW every 10 minutes Moved at 9:40 so can be moved 9:50 Central
Set 1 Cryptus Sepultus Set 2: Fantasy Tavern
Props: Hood Huntress Collection Boned Wings for G3/8 Midnight Skeleton
Character: Iray Alligator By AM
Kismet2012
Set 1: Bend of the River Cafe Luca
Props: Laser Toss Arcade Game (Prop) Porta Potty (Potty)
Iray Snow, Light and Ash
Character: Abel for Genesis 3 Male
LaPetiteVerita
Set 1: Enchanted Ballroom Patio Dining Set
Props: Jacuzzi Deck (Deck Chair 1 Red Cushion) RW Rafting Fun (Raft)
Blade Weapons (Rip Saw)
Character: Toon Generations Two Essentials
Nonesuch00
Set 1: Versatile Terrain Set 2: Northern Terrace Street
Props: The Gardener's Potting Shed Tools (Wheelbarrow) Urban Warrior (Large Sword)
Character: Baby Packy
Novica
Set 1: DA Palm Island Set 2: Fancy A Game Of Chess
Props: Multi Letter System (Prop X Standard Font) Scrappy The Robot
Grapevines (Grapes)
Character: Sakura 8
RGcincy
Set 1: Abandoned Gas Station Set 2: Summer Gazebo
Props: Dream Home Great Room Access. (Bench) Steampunk Vent (Gears)
Character: Floyd 8
Saphirewild HAD OLD HAGRED.
Set 1: Generic Sci Fi Corridor Set 2: Velodome Track
Props: Daybed Romance Ace of Spades Jack (Backpack)
The Firearm Pack (#2 Rifle)
Character: Belladonna for V4
Stormlyght
Set 1: Mystical Cave Set 2: The Void
Props: Poseable Peonies (Bush Double 2) Iray Ghost Light Kit 2 (flashlight)
Cyber D Model 1 (Prop, not living)
Character: DA Unicorn for Daz Horse 2
xmasrose Has had Old Hagred
Set 1: Bar Interior 2018 Set 2 Disconsolation
Props: Morphable Meershaum (Pipe)
Inflatable Boat (Outboard Motor) Daz Water Pump/Grain Silo (Water Pump)
Character: Toon Alien
TIMELINE
Yep, this is the fun post to watch. Want to know the mischief players are causing? This tells you who teamed up wtih whom, and who was on the receiving end. Then you can watch the payback. Who is the initiator of gutsy moves? What are the products getting shuffled around? Can you see a player's strategy? Are the other mischief makers clueless?
Where is Old Hagrad?
I wouldn't "just" use this list to watch the game. The BEST part is the trash-talking between players, and the "encouragement" of players to do-it-to-it to other players.
ALL TIMES ARE CENTRAL TIME (Florida)
August 11: 10:45 Game is about to kick off!
August 11: 10:45p Novica sent RGcincy Old Hagred so he could get a kiss. He has 6 hours to pass her along or we do it.
August 11: 10:47p Novica NSF #5 Kismet2012. Kismet had to give up Make A Wish Props (Scepter) and take Piercings Collection (Nose Piercing.)
August 11: 11:25p Cancelled, it's a tricky move and we'll do it again later.
August 11 11:30p 3dcheapskate NSF #1 which is swapping an item for another one that they own. ONE TIME USE. Got rid of Warrior Maiden Tanwen and took Yasuo for Lee 6
August 11 11:57p RGcincy decided Old Hagred just wasn't his type. Feeling sorry for barbult who must've eaten some Rat's Tail Dessert, he is sending Old Hagrad to help figure it out. Barbult has until 5:57am to pass her along or we do it for her.
August 12 12:16a RGcincy NSF #5 to jakiblue Say Bye And Hi He told her Aibell (Character) is tired of playing the game but Baby Packy is more than ready. (So now she has a big elephant to take care of.)
August 12 12:25a 3dcheapskate NSF #5 Say Bye And Hi. Feels that IceDragonArt needs to have a character with some BITE to it. Say bye to Aibell and hello to Sharks by AM: Great White Shark
August 12 12:28a 3dcheapskate #5 is on a roll targeting IceDragonArt, now NSF #5 again, Say Bye And Hi. She must replace Black Market Blade Silent Death (Twisted Blade) with prop Interstellar Killsat (from Stellar Fury.)
August 12 1:37a Novica NSF #2 We're Swapping Says Me to jakiblue. Novica forced a swap of The Ministry onto jakiblue, and took her Forgotten Tunnel Entrance. (Both items must be in each other's possession, it's a bit harder to do.)
August 12 2:19a Novica NSF #4 You and You swap to barbult and 3dcheapskate, because he's been having too much fun doing things to others and not getting anything done to him. She forced a swap between 3dcheapskate and barbult. 3dcheapskate gave up The Alcove to barbult and she gave up DM's Anardhaus to 3dcheapskate. (You must have the players swap the same TYPE of item. Both are sets.)
August 12 3:04am Novica just gave away some research so someone else can do a NSF #4. The first game player to claim it doing what she told them to do, gets it. Valid until 6:04am then she will use it. RGcincy and dreamfarmer can use the information and do a #2 We're Swapping Says Me if either wants to claim it.
August 12 3:22am 3dcheapskate makes a return move on Novica with NSF #5 (Sending one to the list and telling her what to get in return. Must be the same type item.) So BD Aspen is replaced with "even cuter Nybras." 3dcheapskate's words, not mine.
August 12 3:46am xmasrose claimed the free research.
August 12 4:09am xmasrose NSF #4 You and You Swap. RGcincy must give Sci-Fi Cockpit Interior to Dreamfarmer, who must give RGcincy Fantasy Cavern. She said RGcincy needed some fantasy in his life, and Dreamfarmer can welcome the future.
August 12 4:11am Novica NSF #2 We're Swapping Says Me Being stuck with Nybras, plans a double move. Watch and learn. Remember 3dcheapskate made poor IceDragonArt take that Great White Shark? Novica takes the shark from IceDragonArt who then gets stuck with Nybras.
August 12 4:11am Novica's second move- NSF#2 again, We're Swapping Says Me. She dumps the AM Sharks: Great White onto unsuspecting Stormlyght and takes Stormlyght's adorable Keiko 6. So Nybras is IceDragonArt's problem, the shark is Stormlyght's pet, and Novica ended up with adorable Keiko 6. Thanks 3dcheapskate.
August 12 4:30a xmasrose NSF #5 Say Bye And Hi (force someone to give something up and chose what they take from the list)
to nonesuch00. She heard nonesuch00 had a fight with Sakura so she sent her packing, and the gentle dolphin is taking her place.
August 12 5:18am Barbult refused to let someone stick her with Old Hagred. She stated, "I'll get you later RGcincy!" and sent the witch onto unsuspecting Wonderland. Wake up Alicia! You have until 11:18am Central Time to send that gal on her way.
August 12 5:42am Kismet2012 NSF #5 Say Bye And Hi (tells her what to give up, and what to take from the list.) Thoughtful Kismet2012 allowed Novica's toilet to depart and Novica took the walker from Senior Walker Prop. Novica is actually grateful and will see what she can do for Kismet2012. EDIT: five minutes later, Novica realizes what a slick move that was. She and Kismet2012 are the only two who own that, so Novica is stuck with it. For now.
August 12 5:51am 3dcheapskate NSF#4 You And You Swap nonesuch00 took Medieval Castle Interior from LaPetiteVerita. LaPetiteVerita took Patio Dining from nonesuch00.
August 12 5:58a kismet2012 NSF #6 I'll Take That, Thanks. Took the flashlight prop from Iray Ghost Light Kit 2 from LaPetiteVerita, had her replace it with Fluttery Wings(G3) (Dragonfly). Kismet2012 had to give up the Mistletoe Cookie from Christmas Cookies.
August 12 6:48am kismet2012 NSF #7 You're A Thief to Saphirewild. She must steal that sweet lil Dolphin from nonesuch00
@saphirewild You must now give up an item of the same type (Character) and pick a character from the MAIN LIST for nonesuch00
Because you only have one character to give up RDNA Sluggians went to the main list and is now available for others to use.
August 12 7:14am Kismet2012 NSF #4 You And You Swap. xmasrose will swap the Diary (Open/Close) from Everyday Stationary with Barbult, who will swap out the Corkscrew from Wine Me.
August 12 8:00a Kismet2012 NSF #5 Say Bye And Hi to Wonderland. Bye went Monique 7 and she must say hello to the "adorable Benji Puppy HD" for Daz Dog 8. "He's just so cute." Keep an eye on Kismet2012- Wonderland is the ONLY one who owns that. You know what that means- and so does Kismet2012.
August 12 8:10a xmasrose NSF #5 to RGcincy because a close friend told her FW Laverne HD is not happy with him anymore and Morpheus "is in need of a good friend, poor thing is so lonely.." So Bye Laverne and Hi Morpheus.
August 12 8:26 3dcheapskate NSF #5 Say Bye And Hi to Novica. Because Nybras departed Novica's company, he thwarted her plan of ending up with Keiko 6 and made her give Keiko up. She is now the proud owner of a Housefly.
GAME PAUSED so Novica could add all the currently owned in the main list as red items.
August 12 10:19a Stormlyght NSF #5 Say Bye and Hi to nonesuch00 who must give up Versatile Terrain and take Jacuzzi Room. Oh, and she says she doesn't need a Moon Broom (you know, the move that got cancelled? She went after you anyway.)
August 12 10:32a Kismet2012 NSF #4 You And You Swap. Stormlyght will swap Winterblack Tower for dreamfarmer's DM's Cave of Secrets.
August 12 10:33a RGcincy NSF #7 Novica. You're a Thief. Okay folks this IS how you do it. RGcincy tells Novica who to steal from, and what to steal. THAT IS IT for RGcincy. She is stealing Mortuorum Sanctis (Coffin Lid) from 3dcheapskate. This is NOT GOOD NEWS FOR 3dcheapskate. (Thanks RGcincy!)
Because NOW Novica takes the pesky coffin lid (a prop) but gets to give up a prop to the list because she has too many props. It's her choice, so she dumps the Senior Citizen Prop (Walker) and gets to decide what prop 3dcheapskate has to take from the list. RGcincy just put himself on 3dcheapskate's radar. Novica decides that 3dcheapskate is the proud owner of Jump Your Way (Full Gate 4) because he's so good at horsing around in this game.
So note- the initiator of the NSF (RGcincy, decides who steals, (Novica) who they steal from, (3dcheapskate)and what they steal. (the coffin lid.) The person doing the stealing (Novica) decides what they have to give up to the list (same type item) (walker) AND what the person they stole from (3dcheapskate) has to take from the list (jumping gate) to replace the lost item. THIS IS A GREAT WAY TO GET NEW ITEMS INTO THE YES I OWN IT LIST.
August 12 10:45a dreamfarmer has arrived. NSF #6 I'll Take That. She takes from xmasrose, a character, Star 2.0 so now dreamfarmer must get rid of hers. (We only have 1 character, so there's no choice. Had it been a prop or set, she would chose 1.)
So she took Star 2.0, dumped her character Tiami back out in the main list. Now poor xmasrose is without a character, and dreamfarmer gets to choose what to give her. Dreamfarmer is a very nice person as she chose Noodles the Toon Cat.
August 12: 10:59a dreamfarmer NSF #5 Say Hi And Bye to Novica who gives up the Kelp (Aguja Undersea Environment) so she can get some Epic Wings for the Housefly. So thoughtful.
August 12 11:05a LaPetiteVerita NSF #5, has now joined the fun. Say Bye And Hi on Kismet2012 who gives up Collective3d Portrait Vignettes Old West and gets Velodome Track from the main list.
August 12 11:08a Kismet2012 NSF #7 You're A Thief to IceDragonArt who must steal Old West Bath House (a set) from jakiblue.
Okay, IceDragonArt (the person doing the stealing) decides what item they give up to the main list AND what the person they stole from (jakiblue) has to take from the list (a set) to replace the lost item.
IceDragonArt is not online, we think- so at 1:08 (two hours from now) I will assign someone to pick a set for jakiblue from the main list, and which set IceDragonArt must give up.
August 12 11:15a LaPetiteVerita NSF #7 You're A Thief to Novica who must steal an earring (Jeweled Excellence Earrings 2) from Wonderland. (Novica thinks her fly will look just dandy with those btw.) Novica now has too many props and (yes, keeps the coffin lid) and gets rid of the Horse Drawn Carriage (Daz Horse 2) She gets to decide the prop for Wonderland and chooses Basketry.
August 12 11:20a xmasrose knew Wonderland hadn't come online to pass along Old Hagred, so she did it for her. 3dcheapskate is the new recipient and has exactly 6 hours which is 5:20p to give up the witch.
August 12 11:28a RGcincy NSF #6 I'll Take That (steal an item and decide what they take from the list, then because you have too many you must give the same type item up.) He is of the opinion he can use Tangien Portico better than xmasrose but tries to soften the blow (after insulting her) by sending her Bar Interior 2018 to get drinks. Because RGcincy has too many sets, he has to give one up and away goes Parkside Head Interior. "Too gloomy for my tastes."
August 12 11:38a Stormlyght NSF #7 You're A Thief She tells Barbult to steal Morpheus from RGcincy. She's done.
Now barbult has to get rid of her character, as she can only have one, so Yasuo for Lee 6 is moved to the main list. She has until 3:30p to choose a character for RGcincy.
August 12 11:56 Stormlyght NSF #4 You And You Swap. All RGcincy had to do was wait and that Porta Potty would be on its way. Yep, Stormlyght made Kismet2012 give up that Piercing Collection (Nose Piercing) and take the Porta Potty, and RGcincy can now figure out how to do a nose piercing.
August 12 12:08p Stormlyght was asked to pick a character for nonesuch00 from 6:48am this morning. (We won't wait that long in the future, but since that was an early morning hour, we waited to wait a bit.) She chose Warrior Maiden Tanwen.
August 12 1:42p Stormlyght #5 Say Hi And Bye to Wonderland, stating Benji the Puppy HD (Daz Dog 8) didn't want to play so off it goes to the main list and in return, Wonderland gets Botan HD (Gen8F)
August 12 1:46p RGcincy was asked to pick a set for jakiblue and it was already taken. He wanted her to have a nice relaxing day in the water. What a nice guy. He's trying again and I will come back and post it. He must also decide which ones of IceDragonArt's sets has to be given up.
August 12 2:20p Stormlyght did NSF #2 We're Swapping Says Me with LaPetiteVerita Stormlyght gave her GIS Nova and LaPetiteVerita gave up Patio Dining to Stormlyght. Talk about a switch!
August 12 2:23p barbult picked the character for RGcincy and it's Vampire Bat by AM. Great choice! (Make sure you're on his RADAR RGcincy.)
August 12 2:53p Stormlyght NSF #6 I'll Take That, Thanks and swooped in on RW Letters and More (Letter Q) owned by Saphirewild. She chose Daybed Romance for Saphirewild. Because she now has too many props, Stormlyght gave Z Deadly Weapon Gun (Silver Gun) back to the main list.
August 12 3:09p barbult makes her presence known with a NSF #5 Say Bye and Hi to Stormlyght stating the letter Q doesn't suit her. RW Letters And More (Q) heads to the list and Multiletter System (X Standard Font) gets a new home with Stormlyght.
Timeline paused, game play can continue but I will be offline about 8 hours. (11pm tonight, central time.)
Times were taken off due to forum going to "next day." Will do brief summaries. It's taking too long to link the posts and times, so will just be doing summaries without those.
Barbult NSF #7 You're A Thief to RCcincy who steals Janitor Gear (Prop Push Broom) from nonesuch00
Barbult NSF #4 You And You Swap for Novica and xmasrose. Novica gave up Mortuorum Sacris (Coffin Lid) and got The Werks Mega Prop Collection (Lollipop) from xmasrose. Sweet deal!
Stormlyght NSF #6 I'll Take That, Thanks to Wonderland. She takes Cyber Wings and sends Symphonic Sounds/Poses (AMP) to the main list. Wonderland gets Fantastical Sprite Wings.
Kismet2012 NSF #4 You and You Swap RGcincy swaps Tangien Portico and xmasrose swaps out Tree and Swing.
Dreamfarmer NSF #6 I'll Take That, Thanks. Done to Saphirewild. She takes A Curious Hallway, sends Sci-Fi Cockpit to the main list as she'd have too many sets otherwise, and replaces the hallway she took with Disconsolation for Saphirewild.
NEXT PAGE
Kismet2012 passed Old Hagred along on behalf of 3dcheapskate who is on a different schedule. The recipient is dreamfarmer.
IceDragonArt NSF #6 I'll Take That, Thanks to RCcincy. She took New Colony Props (Module 3e) and he gets Beer Props (Green Tablecloth) She gave up the Kick Scooter
Kismet 2012 NSF #2 We're Swapping Says Me Sent LaPetiteVerita Zoey for Victoria 5 and took FWSA Pepper.
IceDragonArt NSF #5 Say Bye And Hi to 3dcheapskate who gave up Technophilia Arcane Star Scope (Scope) and got Chainsaw.
3dcheapskate NSF#2 We're Swapping Says Me to Saphirewild and swaps Ace of Spades Jack (backpack) with Steam Bike Pro Pile of Luggage, a duplicate. Novica implements a new rule about duplicates so others won't have them. 3dcheapskate bailed out Saphirewild.
RGcincy gets jakiblue a different set (from a previous post) and it's Northern Terrace Street.
Since he had to steal, he gives up Piercing Collection (Nose Ring) and also designates nonesuch00 gets the Formula 1 Race Car.
August 12 RGcincy NSF #5 Say Bye And Hi to Wonderland. She loses DM's Dark Shrine and gets Chinese Courtyard. Both are sets.
August 12 Dreamfarmer says "Ack!" and sends Old Hagred to jakiblue.
August 13 NSF #8 Fetch It, Thanks! is announced. It combines the Say Bye And Hi and We're Swapping Says Me. A player tells another one which item goes to the list, and which one replaces it. (NSF #5, Say Bye And Hi.) THEN #2 We're Swapping Says Me kicks in where the player takes the item just fetched from the list.
August 13 Novica NSF #5 Say Bye And Hi to barbult, who gives up the boring Vintage Boxing Accessories (Speed Bag) and takes Signs of Protest (Sign Left Hand)
August 13 Novica NSF #5 Say Bye And Hi to dreamfarmer, who gives up that boring Star 2.0 and gets Troll Beast.
August 13 Novica NSF #5 Say Bye And Hi to nonesuch00 who gives up Warrior Maiden Tanwen and gets Genesis Cupid. Awww!
August 13 xmasrose NSF #2 to RGcincy We're Swapping Says Me She dumps that coffin lid (man, it gets around) from Mortuorum Sacris onto RGcincy and takes his Janitor Gear (Push Broom.)
August 13 Novica demonstrates the NSF #8 new move. Fetch It, Thanks! She makes sure someone owns Jeweled Excellence, that would be LaPetiteVerita among others. Always check the person owns what you are going to swap with them later. So Novica sends LaPetite Verita to pick up a prop that Novica also owns. LaPetiteVerita picks up Architect Office (Buddha) Upon returning, Novica says hand it over, and gets the Buddha, giving LaPetiteVerita the Jeweled Excellence. It is simply a combination of Say Hi and Bye, then We're Swapping Says Me. You get to ensure what you want to swap is something YOU picked out! (and it only counts as one NSF!
The new NSF#9 is also in play. You pick up an item for a person which they and another person both have, and send one to the main list. Then you have two players do a swap. This combines Bye And Hi with the You And You Swap. You make all the decisions.
5:08am xmasrose NSF #5 Say Bye And Hi to Kismet2012 Collective3d Portraits Vignettes Old West 2 goes Bye and Bend of the River says Hi. Now Kismet2012 will spend more time outside.
5:21a kismet2012 is off and running with the new NSF #8 Fetch It, Thanks! xmasrose gave up Tangien Portico, then went to fetch Daz Barn and kismet2012 took it and gave her Velodome Track.
6:20a 3dcheapskate NSF #7 You're A Thief for barbult to steal School Lunch Props (Prop: Closed Lunch Bag) from Kismet2012. Now barbult must give up the same type item and tell Kismet2012 what item will replace the one given up. Barbult gave up the Laundry Day Mega Set and Kismet gets the Laser Toss Arcade
7:19a xmasrose NSF #7 You're A Thief to dreamfarmer who must steal Jump Your Way from 3dcheapskate (because she needs a gate to escape from the Troll.) (Hmm, Novica was responsible for giving both those items...) Now dreamfarmer must give up the same type item and tell 3dcheapskate what item will replace the one given up. She will give up Monster Skulls and 3dcheapskate gets Dystopian Console.
7:23a LaPetiteVerita NSF #5 Novica Say Bye And Hi Novica FINALLY gets to tell the fly to buzz off, as "insects are never fun to deal with." She gets Sakura 8.
7:35a xmasrose NSF #5 to Barbult who gives up Everyday Stationary (Open/Closed Diary) and says Hi to Daz Water Pump /Grain Silo (Water Pump) "Don't lose time writing when you should water the crops!"
7:37a LaPetiteVerita NSF #2 We're Swapping Says Me on Wonderland LaPetiteVerita wanted toget Basketry and give Wonderland the Public Indoor Pool (Lifesaver) Move can't be made- Wonderland doesn't own the pool
7:47a LaPetiteVerita NSF#9 She shows you how its done! This is going to require at least ONE of the two players to own the item in the other person's possession. So here goes- Stormlyght HAS the Great White Shark in her possession. (IceDragonArt owns it too, but doesn't HAVE it obviously.) Step 2 IceDragonArt's character is Nybras, this goes to the list because it isn't owned by both. IceDragonArt brings back Feathered Dragon, because they both own it. IceDragonArt gives Stormlyght the Feathered Dragon, and Stormlyght gives IceDragonArt the Great White Shark. (which is WHY YOU MUST START OFF WITH ONE PRODUCT IN POSSESSION THAT BOTH PEOPLE OWN.)
Old Hagred has made her appearance, leaving dreamfarmer and visting Saphirewild.
GAME PAUSE
10:55a IceDragonArt NSF #4 can't be done as both parties don't own the articles.
11:10a dreamfarmer demonstrates NSF #9 Fetch Now You Two Swap. Novica gave up The Werks Mega Prop Pack (Lollipop) and brought back Thursdays Child Deaddy Bear, which was swapped with xmasrose's Wine Me (Corkscrew.) So xmasrose got the Thursdays Child Deaddy Bear and Novica got the Wine Me (Corkscrew.) This was all possible because Novica had Wine Me. You MUST have an item ALREADY IN POSSESSION that both players own.
11:14a 3dcheapskate NSF #2 We're Swapping Says Me with dreamfarmer who takes Summer Gazebo and gives A Curious Halway to 3dcheapskate.
11:16a IceDragonArt NSF #8 Fetch It For Me, Thanks! IceDragonArt sends Barbult to the list to grab Hood Huntress Collection for her, and barbult gives up School Lunch Props so she can do it. When the Hood Huntress Collection gets back, IceDragonArt takes it and gives barbult the Stellar Fury in her possession (because they both own it.) See how this works? (And it's just one person dictating it, my verbs are just to make it easy for you to visualize. Barbult never "does" anything.
11:23a Dreamfarmer NSF #1 I'll Swap With List ONE TIME USE. She swaps Troll Beast for HP Yuka (Aiko 8)
11:23a Dreamfarmer NSF #5 Say Bye And Hi with IceDragonArt who says Bye to Aeridian Interstellar Throne Room and Hi to aMAZEing Journey Around The World.
11:48a RGcincy NSF #2 We're Swapping Says Me with Kismet2012 who gets the Tree and Swing (Set) while giving RGcincy the Daz Barn.
12:05p RGcincy NSF #8 Fetch It For Me, Thanks! LaPetiteVerita gives up Crystal Vases (Twisty Vase) and goes and gets Medieval Hall and Garden (Prop-Barrel On Stand) which RGcincy takes and gives her Beer Drinking Props (Green Gingham Tablecloth)
12:08p barbult NSF #A2 We're Swapping Says Me to RGcincy who gets The Alcove and she gets Daz Barn.
12:1p barbult NSF #2 We're Swapping Says Me Kismet2012 is getting Shoot First Corner and barbult gets Tree and Scene
12:44p Old Hagred was passed along to someone who already had it.
1:14p Saphirewild Need a bit of clarification.
Aug 13th afternoon: IceDragonArt NSF#7 You're A Thief to nonesuch00 who takes BBQ Grill Collection from Wonderland. Nonesuch now must give up an item and replace an item for Wonderland. Wonderland is no longer in the competition (never got to start.) Nonesuch gave up Formula1 Race Car.
barbult NSF #6 I'll Take That, Thanks to jakiblue. Barbult takes the Lemonade Stand and gives up Stellar Fury, and jakiblue gets the Kick Scooter.
nonesuch00 Can't do that move as the people don't have item in possession. (Wonderlands Old West 3, DM Dark Shrine move.) Barbult pointed it out.
IceDragonArt NSF #4 You And You Swap jakiblue swaps her Baby Packy for Novica's Sakura 8
Kismet2012 NSF #9 Fetch Now You Two Swap Both players 3dcheapskate and Novica own DM's Anardhaus. Novica gives up i13 Foxy Lounge and takes an item both players own, Crypta Sepultus. 3dcheapskate then is given Crypta Sepultus, Novica gets DM's Anardhaus from 3dcheapskate.
Stormlyght sent Old Hagred on her way to IceDragonArt
Stormlyght NSF #6 I'll Take That, Thanks to jakiblue, taking Sakura 8, returning Feathered Dragon to the list, and giving jakiblue Aibell (G3)
Stormlyght NSF #8 Fetch That, Thanks and has Novica ditch her Wine Me Corkscrew so she can go fetch the SY Super Splash Pack Iray for her. She gives Novica the SY Rigged Waterfalls Iray that she had in her possession.
LaPetiteVerita NSF #4 You And You Swap xmasrose gets Tree and Swing, barbult gets Velodome Track.
LaPetiteVerita NSF #8 Fetch That, Thanks and has RGcincy ditch the Mortuorum Sacris (Coffin Lid) (that thing really gets around) to go fetch the Jacuzzi Deck (Deck Chair red cushion) for her. RGcincy then gets LaPetiteVerita's Public Indoor Pool
Barbult NSF #2 I'll Take That, Thanks barbult takes the Abandoned Gas Station and gives Saphirewild the Velodome Track. (that also gets around alot)
Stormlyght NSF #9 Fetch Now You Two Swap Aw, poor Noodles The Toon Cat got sent back to the list by xmasrose who picks up She Freak V4 from the main list. xmasrose gives 3dcheapskate the She Freak V4 and 3dcheapskate gives Yasuo for Lee 6 to xmasrose.
From the earlier moved (marked in red, previous post) nonesuch gives up the Formula 1 Race Car and has Wonderland take the Sakura Ultimate Tree
nonesuch NSF #7 xmasrose You're A Thief. She takes Daz Water Pump/Grain Silo (Water Pump prop) from barbult. Now xmasrose decides which prop she has to give up, and what prop barbult gets to replace the one taken.
nonesuch NSF #6 I'll Take That, Thanks with jakiblue, taking her Northern Terrace Street, and sending his Medieval Castle Tower Interior to the list (otherwise he'd have too many sets.) Then he picks from the main list to replace the set he took, and gives jakiblue Picnic Area Exterior.
GO TO NEXT PAGE
AUGUST 14
nonesuch #5 Say Bye And Hi He has Saphirewild say Bye to Disconsolation and Hi to Generic Sci Fi Corridor.
nonesuch #1 I'll Swap With List Moves his Northern Terrace Street to the list and takes Versatile Terrain.
For nonesuch's #7 You're A Thief, (earlier post) xmasrose gave away Janitor Gear and to replace the prop she stole from barbult, barbult got Kick Scooter.
nonesuch is given credit for NSF #5 sending Wonderland to the list (getting rid of Basketry) and taking Everyday Groceries. He did that before it was announced she wasn't in the game. (Never started, had mentioned beforehand she may not be able to play. At this point, it's too late to start.) His earlier #4 at 3:14am is not valid (not posted here.)
3dcheapskate has got NSF #9 down pat. Stormlyght ditched SY Super Splash Iray Pack, fetched Jackson's Field (she and RGcincy both own it.) She gives Jackson's Field to RGcincy and RGcincy gives her Medieval Hal and Garden (Prop-Barrel on Stand.) That item was owned by both and in ONE of their possession at the time. That's really all you have to look for to start this rolling!
3dcheapsake has this down pat. NSF #9 Novica ditches Epic Wings and fetches Cyber D Model 1 (Prop) which she swaps with Stormlyght. She takes Stormlyght's Multiletter System (Prop X standard font) This all worked because both folks owned the letter system. See how easy this is?
The game has been extended to 10am Central time, Wednesday morning. It had to be paused for Novica to catch up as gameplay proceeded while she was offline. (Yep, have to sleep sometime!) Busy little beavers so there was a backlog. (Aka, everything from early morning hours, all of the activity above!)
Old Hagred has made her move and now she is with nonesuch00. Stormlyght realized IceDragonArt had been warned about her complexion turning green and warty if she dared pass her along, so brave Stormlyght is pitching in and moving her. We'll have to keep track of Stormlyght's condition.
New twists for passing along Old Hagred!
nonesuch00 wasted no time in ditching the witch Old Hagred over to Kismet2012. xmasrose is the only one left for round 1 and we'll give Kismet2012 the chance to do that. After six hours we'll start over again and she can be sent to anyone. Strategy comes into play here.
xmasrose NSF#6 I'll Take That, Thanks xmasrose to Novica: xmasrose wants Baby Packy to play with her Deaddy Bear but graciously gives the horse owner DA Unicorn for Daz Horse 2 to replace her loss of Baby Packy. xmasrose ditches Yasuo for Lee 6 as she'd have too many characters.
7:22a Well Kismet2012 is on the ball and Old Hagred scooted over to xmasrose. SHE CAN BE MOVED AT 11:22a
7:57 kismet2012 NSF #9 Fetch Now You Two Swap Novica and nonesuch00 Novica ditches the Architect Office (bye bye Buddha) and fetches Urban Warrior (Large Sword) and swaps that to nonesuch00. Nonesuch00 gives her the Geisha Prop Collection (4 Asian inspired fans)
8:45a kismet2012 and Novica discussed getting dreamfarmer more involved with changes, and Novica is kinda busy so kismet2012 to the rescue.
Kismet2012 NSF #4 You And You Swap RGcincy and dreamfarmer RGcincy gets a Summer Gazebo (to go with The Alcove) and dreamfarmer takes his Fantasy Tavern.
9:09a xmasrose isn't afraid to rat out LaPetiteVerita to Old Hagred. Uh oh. (What'd she ever do to you?) Old Hagred can be on the move at 1:09 if LaPetiteVerita doesn't move her by then. (Assuming she is ABLE to...)
9:42a xmasrose #8 Fetch It For Me, Thanks! xmasrose gets IceDragonArt to give up Old West Bath House so she can fetch Disconsolation. Then IceDragonArt swaps Disconsolation to xmasrose and takes her Tree And Swing.
10:02a LaPetiteVerita seems to have no regrets about stealing the broom, but she hustles Old Hagred to barbult before the witch gets an angrier. Old Hagred can be on the move at 2:02p if barbult doesn't move her out!
10:15a dreamfarmer NSF#5 Say Bye And Hi 3dcheapskate puts Steam Bike Pro (Pile of Luggage) back in the list and takes Regenerator (Prop)
10:21a 3dcheapskate NSF #5 RGcincy ditches Public Indoor Pool (Lifesaver) and gets Stellar Fury (Interstellar Killsat)
10:49a RGcincy NSF#5 Say Bye And Hi 3dcheapskate gives up Chainsaw for Morphable Meershaum (Pipe) RGcincy says 3dcheapskate has been too busy doing NSFs and needs to take time for a relaxing smoke. (Translation: he's just trying to get 3dcheapskate preoccupied so he won't mess with him)
10:53a RGcincy NSF #5 IceDragonArt ditches Gothic Bedroom and gets Black Market Blades Silent Death (any blade) back again. We'll all have to do something about that (he offered to undo it but she said it was fine.)
11:11a dreamfarmer #5 Say Bye And Hi RGcincy gives up the Vampire Bat and gets Kincaid
11:21 RGcincy #5 Say Bye And Hi He didn't realize dreamfarmer keeps getting the same character. dreamfarmer got to replace Troll Beast with Charlotte 8
11:27 IceDragonArt #7 You're A Thief RGcincy must steal BBQ Grill Collection (Grill) from nonesuch00 and designate a replacement prop for nonesuch. He must also decide which item he has to give up because now he has too many props.
EDIT NOVICA WILL DECIDE AFTER PROCESSING ALL GAMEPLAYS AFTER THIS ONE.
NEXT PAGE
11:35a Saphirewild NSF #5 Say Bye And Hi RGcincy gives up the Golf Course Props (Cart) and gets the Dream Home Great Room Accessories (Prop: Bench)
11:53a nonesuch NSF #8 Fetch It For Me, Thanks! Barbult gave up Daz Barn to go get Disconsolation, swapped that to nonesuch and received Jacuzzi Room.
11:53a nonesuch NSF #8 Fetch It For Me, Thanks Dreamfarmer takes Jackson's Field (Prop: Fingerpost Sign) from RGcincy. Dreamfarmer must now decide what prop to give up, and what RGcincy takes. (I am reading through the posts to see if that was done before I put a stopplay on his props.) I'll get to it, not skipping posts.
11:53a nonesuch NSF#4 You And You Swap Stormlyght gives Patio Dining (Set) to LaPetiteVerita and takes her GIS Nova.
11:53a nonesuch NSF#5 Say Bye And Hi Novica gave up DM's Anardhaus and took Fancy A Game Of Chess.
11:55a IceDragonArt NSF#5 Say Bye And Hi Saphirewild said bye to that swimmingly adorable Dolphin and took Belladonna for V4.
12:08 Dreamfarmer (from 11:53a Thief post, above) decides to give up Sweet Temptation and decides RGcincy teakes Steampunk Vent (Gears.)
12:10 IceDragonArt NSF #4 You And You Swap Novica gives away Forgotten Tunnel Entrance to xmasrose who gives her Disconsolation.
Looking through all the RGcincy posts (got caught up) none involved the props so the second slot one (predetermined slot, I processed all the rest of the posts and made any changes before the stopplay on his props) was Stellar Fury and I removed it. He has the Dream Home Great Room Accessories (Bench) Steampunk Vent (Gears) and BBQ Grill Collection (Grill) You can make moves with his props.
Also, having gotten through the posts, I had to designate a prop for nonesuch00 He gets Scrappy the Robot. (not a living thing, so it's a prop.) Can't believe Scrappy has been ignored this entire game!
12:19p Saphirewild NSF #4 You And You Swap xmasrose sadly said goodbye to Thursdays Child Deaddy Bear and 3dcheapskate gave her Morphable Meershaum (Pipe)
12:38 Dreamfarmer and IceDragonArt NSF #3 We Agree To Swap Dreamfarmer gives IceDragonArt Fantasy Tavern, and gets aMAZEing Journey Around the World.
12:45p Old Hagred tried to move out a bit too early, but the graphic is adorable.
1:08 LaPetiteVerita NSF #6 She puts Zoey for Victoria 5 back in the main list, and takes RGcincy's Kincaid. She gives him Raelyn for Stephanie 4 from the list.
3:34p Not showing RGcincy as having Regenerator in his possession at this time. We're looking into if it is my error :)
4:05 Novica moved Old Hagred along to RCcincy, as did barbult. We REALLY wanted to get her to him!
4:27p Novica NSF #9 Fetch Now You Two Swap LaPetiteVerita puts Industrial Storage Unit Interior back in the main list and retrieves Old Country Farmhouse. She swaps that to barbult and takes barbult's Abandoned Gas Station. LaPetiteVerita had been stuck with that storage unit since the game began, so Novica wanted her to get a variety.
4:32p barbult NSF #2 We're Swapping Says Me IceDragonArt takes Jacuzzi Room and barbult takes Tree And Swing.
Game Paused, ran from 2am until 5:15pm so everyone had a chance to play. The players will take responsibility for moving Old Hagred along according to the new rules, and to double check each other if I am not back online at midnight. The game STARTS AT MIDNIGHT CENTRAL TIME (that's one hour BEFORE DAZ MIDNIGHT when the store turns over, if that helps.)
12:12am August 15TH GAME ON! NEW PROCEDURE- Players are to wait if the timeline is THREE POSTS behind.
Old Hagred has gone to Stormlyght, Saphirewild, nonesuch, and 3dcheapskate.
12:03a Stormlyght NSF #6 I'll Take That, Thanks. Stormlyght takes Kismet2012's Iray Ghost Light 2, Kismet gets Iray Snow, Light, and Ash from the list. Stormlyght has too many things so Medieval Hall and Garden goes back to the list.
12:23a RGcincy NSF #1 ONE TIME USE I'll Swap With List RGcincy swaps out Raelyn for Stephanie 4 with Floyd 8
1:12a Novica NSF #5 xmasrose returns Vintage Luggage (Briefcase) to the list and takes Playtime (Hobby Horse) xmasrose has had that luggage since the start of the game!
1:12a LaPetiteVerita NSF#8 Fetch It For Me, Thanks! RGcincy ditched The Alcove and got Enchanted Ballroom from the list. He swapped that to LaPetiteVerita and took her Abandoned Gas Station.
1:17a dreamfarmer NSF #5 Say Bye And Hi to Stormlyght She puts GIS Nova in the main list and gets Mystical Cave for Stormlyght.
1:28a Novica NSF #5 Say Bye And Hi nonesuch00 has had Fantasy Scythes since the beginning so that goes to the main list and he gets The Gardener's Potting Shed Tools (Wheelbarrow.) Hint- a lot of people own that, which allows for more gameplay.
1:34a LaPetiteVerita NSF #5 dreamfarmer has had i13 Dreams of the Past (Centerpieces) since the start of the game so it is being replaced with Everyday Groceries (Toilet Paper)
2a Novica NSF#5 Say Bye And Hi 3dcheapskate has had the She Freak for awhile, and the RDNA Sluggians are just waiting to enter the game. So She Freak gets sent to the list and the Sluggians are now keeping 3dcheapskate company.
2:01a LaPetiteVerita NSF #4 You And You Swap Stormlyght gets Disconsolation and Novica takes her DM's Cave of Secrets
NEXT PAGE
2:46 3dcheapskate passed Old Hagred on to IceDragonArt with an offer she just can't...refuse. SHE CAN BE PASSED ON BY ANYONE ELSE AFTER 4:46a CENTRAL TIME
2:52a Novica NSF#9 Fetch Now You Two Swap xmasrose and nonesuch. nonesuch00 ditches Genesis Cupid back to the list and brings back Toon Alien. He then swaps Toon Alien with xmasrose so her Baby Packy goes to nonesuch00. It's a good thing too, because Baby Packy really doesn't like to share the spotlight with anyone and nonesuch00 will pamper him.
3:22a Novica NSF #9 Fetch Now You Two Swap dreamfarmer and Stormlyght Stormlyght ditches Disconsolation back to the main list and picks up Sun Hall (which hasn't been in play yet.) She then swaps Sun Hall with dreamfarmer who gives Stormlyght Winterblack Tower.
3:54a Novica NSF #9 Fetch Now You Two Swap Stormlyght and dreamfarmer Stormlyght ditches Cyber Wings back to the main list (she has two Cyber items and needs some variety.) She gets Poseable Peonies. Then Stormlyght swaps Poseable Peonies with dreamfarmer, who gives Stormlyght Jackson's Field (Prop Fingerpost Sign)
4:30a Novica NSF #5 Say Bye And Hi Say bye to Morpheus and hi to Muck.
4:53a Novica sent Old Hagred to Kismet2012 for 3dcheapskate (who was on the ball and posting same time.)
5:12a Kismet2012 wasn't have it. Er, HER. Old Hagred got sent to Novica. She can be on the move again at 7:12a Central.
5:17a Novica sent Old Hagred to dreamfarmer so she has her. Starting on round 3, everyone is now fair game.
5:15a 3dcheapsake NSF#8 Fetch It For Me, Thanks IceDragonArt gets rid of Jacuzzi Room, and fetches Echoes of Andromeda. She swaps that over to 3dcheapskate, who gives her Cryptus Sepultus.
5:18a Kismet2012 NSF#1 I'll Swap With List Kismet2012 swaps out Shoot First Corner with Cafe Luca.
5:38a Kismet2012 NSF#5 Say Bye And Hi Saphirewild gets rid of Steam Bike Pro (Pile of Luggage) and gets the The Firearm Pack (#2 Rifle)
5:52a Stormlyght NSF #6 I'll Take That, Thanks Stormlyght sends Jackson's Field (Fingerpost Sign) back to the main list. She takes dreamfarmers Poseable Peonies. She then has Dreamfarmer pick up Props Pack: Fun In The Sun (Lounge Chair) as dreamfarmer is short an item.
6:03a Stormlyght NSF#1 I'll Swap With List She says goodbye to Winterblack Tower and takes The Void. The NSF#1 is a one time use.
6:11a 3dcheapskate NSF#6 I'll Take That, Thanks 3dcheapskate gives up Dystopian Console and takes Playtime (HobbyHorse) from xmasrose. Then picks Inflatable Boat (Outboard Motor) so she can putter along.
6:57a Kismet2012 NSF#5 Say Bye And Hi Novica says Bye to DM's Cave of Secrets and Hi to DA Palm Island.
7:06 Stormlyght NSF #2 We're Swapping Says Me with Novica. Novica gets cute Sakura 8 and the DA Unicorn for Daz Horse 2 canters over to Stormlyght's place to check out the stuff she currently has, like Mystical Cave and all the other goodies.
7:06 xmasrose NSF #6 I'll Take That, Thanks nonesuch gives Disconsolation to xmasrose and gets Northern Terrace Street from the list. xmasrose gives us Forgotten Tunnel Entrance (so she can have Disconsolation.)
7:33 Kismet2012 (by proxy, Novica) NSF #5 Say Bye And Hi to LaPetiteVerita who has boring Jeweled Excellence Earrings 2. I mean they're pretty, but in this contest pretty won't win. So RW Rafting Fun (Raft) is more likely to get noticed. Enjoy!
7:46am Old Hagred was sent to xmasrose by Novica She can be on the move starting in about 15 minutes EVERY HOUR.
8:07 Kismet2012 (by proxy, Novica) NSF #5 Say Bye And Hi Bye to Tree And Swing, because it goes too neatly with the country farmhouse. Hi to The Cage.
8:36a xmasrose sent Old Hagred on her way to Saphirewild (that Supersonic Broom is awesome!) At 9:36 anyone can send the witch on the way if Saphirewild hasn't.
9:26a Novica NSF#2 We're Swapping Says Me with nonesuch00 Scrappy The Robot leaves nonesuch00 and he gets the Geisha Prop Collection (4 Asian Inspired Fans) Those fans will keep Baby Packy nice and cool.
9:27a xmasrose NSF #5 Kismet2012 Say Bye to FWSA Pepper and Hi to Abel for G3M
9:39 Novica sent Old Hagred to IceDragonArt and rounding it to 9:40. She can move every 10 minutes.
9:46a IceDragonArt NSF#2 Gave Kismet2012 Crypt Sepultus and wanted Bend of the River Does not work as both parties don't own both sets.
9:52a IceDragonArt NSF#5 Say Bye And Hi LaPetiteVerita says Bye to the boring Beer Drinking Props (tablecloth) and take Blade Weapons (Rip Saw)
9:54a Novica becomes dreamfarmer's proxy but is straightening out IceDragonArt's dilemma.
9:55a Novica uses NSF#1 Swap With List and changes SY Rigged Waterfalls to Grapesvines (Grapes) .
9:59a Novica NSF#5 Novica knows IceDragonArt has had that Sharks by AM Great White Shark forever, so she switches it with Iray Alligator by AM
IceDragonArt having to wait on me to look something up, so I am honoring her last move because we had to chat back and forth. She would have easily posted two or three minutes earlier. The play ONLY involves her.
10a IceDragonArt NSF#1 Swap With List Boned Wings for G3/8 Midnight Skeleton replaces the Black Market Blades Silent Death.
She was so busy with that, Old Hagred ended up with IceDragonArt! It sat in her possession since 9:40am.
10a Novica proxy- Dreamfarmer's Jump Your Way (Full Gate04) is replaced by Laundry Day Mega Set (Empty Dryer)
CONTEST CLOSED AT 10am. IceDragonArt got Old Hagred!!!!
Characters A-M Characters N-Z
Props A-D Props E-J Props K-P Props R-S Props T-Z
Sets A-E Sets F-R Sets S-Z
Red Shows if an item is owned at the moment. Please check the Current Standings page to double check if this is current. There may be a lag.
Characters A- M
Abel for Genesis 3 Male (Character) barbult kismet2012 Novica RGcincy xmasrose
Aibell (G3) (Character) barbult IceDragonArt jakiblue Novica RGcincy Stormlyght xmasrose
Aldo HD and Mustache (Gen8M) (Character) Novica Wonderland
Baby Packy (Character) IceDragonArt jakiblue nonesuch00 Novica RGcincy xmasrose
BD Aspen (V8) Novica
Belladonna for V4 (Character)
3dheapskate IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Saphirewild xmasrose
Benji the Puppy HD (Daz Dog 8) (Character) Wonderland
Botan HD (Gen8F) (Character) Novica Stormlyght Wonderland
CC Lily (Gen8F) (Character) IceDragonArt Novica
Charlotte 8 (Character) barbult dreamfarmer Novica Stormlyght Wonderland
Coral for Callie 6 (Character) nonesuch00 Novica
DA Unicorn for DAZ Horse 2 (Character) IceDragonArt kismet2012 Novica Stormlyght
Dolphin (Character) IceDragonArt nonesuch00 Novica Saphirewild Stormlyght xmasrose
Eaven V4 (Character)
IceDragonArt dreamfarmer Kismet2012 LaPetiteVerita nonesuch00 Novica Saphirewild xmasrose
Elliandra (Gen3/8) (Character) LaPetiteVerita Novica RGcincy
Feathered Dragon (Character) IceDragonArt Stormlyght
Floyd 8 (Character) barbult kismet2012 Novica RGcincy xmasrose
FW Laverne (Monique 8) (Character) barbult IceDragonArt kismet2012 Novica RGcincy Stormlyght
FWSA Pepper (Genevieve7) (Character)
barbult IceDragonArt Kismet2012 LaPetiteVerita Novica RGcincy Stormlyght xmasrose
FWSA Tiami for Callie 6 (Character) dreamfarmer nonesuch00 Novica Stormlyght
Gail for Genesis 8 (Character) Novica Stormlyght
Genesis Cupid (Character) nonesuch00 Novica
Hell Princess HD (Gen8F) (Character) IceDragonArt
Housefly by AM (Character) Novica
HP Yuka (Aiko 8) (Character) dreamfarmer Stormlyght
Keiko 6 (Character) dreamfarmer Novica Stormlyght xmasrose
Killer Bug From Outer Space (Character) IceDragonArt
Kincaid (Gen8M) (Character)
dreamfarmer IceDragonArt LaPetiteVerita Novica RGcincy Stormlyght
Lil Mermaid for Callie 6 (Character) nonesuch00 Novica
Little Ones (Asian Male) (G3M) (Character) barbult nonesuch00 Novica
Monique 7 (Character) barbult dreamfarmer Novica RGcincy Stormlyght Wonderland xmasrose
Morpheus (Gen3M) (Character) barbult nonesuch00 Novica RGcincy
Muck for Genesis (Character) barbult
Characters N- Z
Noodle The Toon Cat (Character) Novica xmasrose
Nybras (Character) 3dcheapskate IceDragonArt Novica
Raelyn For Stephanie 4 (Character)
3dcheapskate IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild xmasrose
Raptor-The Feathered Dragon (Character) Stormlyght
RDNA Sluggians (Character) 3dcheapskate IceDragonArt Kismet2012 nonesuch00 RGcincy Saphirewild xmasrose
Rodrigo (Gen8M) Character Wonderland
Sakura 8 (Character) dreamfarmer jakiblue nonesuch Novica Stormlyght
Sharks by AM: Great White (Character) IceDragonArt Novica Stormlyght
Sharks by AM: Hammerhead (Character) Novica
She Freak V4 (Character)
3dcheapskate dreamfarmer IceDragonArt kismet2012 LaPetiteVerita nonesuch00 RGcincy Saphirewild xmasrose
Star 2.0 (Genesis 3F) (Character) dreamfarmer jakiblue Novica Stormlyght xmasrose
Taric (Gen2M) (Character) IceDragonArt Kismet2012 Novica RGcincy
Tawhak (Character) 3dcheapskate IceDragonArt Novica RGcincy xmasrose
Teen Kaylee 8 (Character) IceDragonArt Kismet2012 Novica
Toon Alien (Character) jakiblue nonesuch00 Novica xmasrose
Toon Generations Two Essentials Gen3 (Character)
barbult LaPetiteVerita nonesuch00 Novica RGcincy Stormlyght xmasrose
Troll Beast (Gen8M) (Character) dreamfarmer IceDragonArt
Vampire Bat by AM (Character) IceDragonArt Novica RGcincy Stormlyght
Warrior Maiden Tanwen (Character) 3dcheapskate barbult kismet2012 LaPetiteVerita nonesuch00 Novica xmasrose
Woolly Mammouth by AM (Character) IceDragonArt Novica RGcincy
Yasuo for Lee 6
3dcheapskate Barbult dreamfarmer IceDragonArt jakiblue kismet2012 LaPetiteVerita nonesuch00
Novica RGcincy Saphirewild Stormlyght xmasrose
Zoey for Victoria 5 (Character)
3dcheapskate barbult IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica xmasrose
PROPS A-D
50's Fabulous Morphing Chair (Prop)
barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica xmasrose
Ace of Spades Jack (Prop- Backpack)
3dcheapskate barbult IceDragonArt Kismet2012 nonesuch00 Novica RGcincy Saphirewild xmasrose
Aguja Undersea Environment (Prop: Kelp) dreamfarmer IceDragonArt Novica Stormlyght
Anime Girl Accessories (G2F) (Prop-Coin Purse) dreamfarmer Novica Stormlyght xmasrose
Architect Office (Prop- Buddha) LaPetiteVerita Novica
Aslan Statues (Prop: the Gargoyle) IceDragonArt jakiblue Novica Stormlyght
Backwoods Shooting Range (Gen3/8) (Prop: Hay Bale) barbult Novica
Basketry (Prop: Birdcage) barbult dreamfarmer IceDragonArt kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild Stormlyght Wonderland xmasrose
BBQ Grill Collection (Prop: Grill) barbult nonesuch00 Novica RGcincy Wonderland
Beer Drinking Props (Prop: Green Gingham Tablecloth) LaPetiteVerita Novica RGcincy Stormlyght
Black Market Blades Silent Death (Prop: Any Blade) IceDragonArt
Blade Weapons (Prop- Rip Saw) barbult Kismet2012 LaPetiteVerita RGcincy Stormlyght
Blade Weapons 3 (Genesis 3 and 8) (Prop-Axe)
barbult dreamfarmer IceDragonArt LaPetiteVerita nonesuch00 RGcincy xmasrose
Boned Wings for G3/8 Midnight Skeleton (Prop-Wings) IceDragonArt kismet2012
Breakfast in Bed (Prop- VB Bowl of Cereal) Barbult Novica RGcincy xmasrose
Building Site (Prop- Shovel) LaPetiteVerita Novica RGcincy
By the Seaside Promenade And Props (Prop- Deck Chair) barbult dreamfarmer Novica RGcincy Stormlyght
CC Angelic Accoutrements (Prop-Rune Halo) dreamfarmer Kismet2012 Stormlyght
Chainsaw (Prop-Chainsaw) 3dcheapskate barbult Novica xmasrose
Chateau Chic Furniture (Prop- Clock) dreamfarmer Novica Wonderland xmasrose
Christmas Cookies (Prop: Mistletoe Cookie)
barbult dreamfarmer IceDragonArt Kismet2012 nonesuch00 Novica xmasrose
Couch Potato Props (Prop:Crisps Floor)
barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Stormlyght xmasrose
Cryo Chambers (Prop- The Chamber) IceDragonArt Novica
Crystal Vases (Prop: Twisty Vase)
barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy xmasrose
Crystals Volume 1 (Prop-Large Blue Quartz) dreamfarmer Kismet2012 Stormlyght
Cyber D Model 1 (Prop- Not Living) Novica Stormlyght
Cyber Wings (Prop: Wings) Novica Stormlyght Wonderland
Daybed Romance (Prop-Full Bed)
barbult dreamfarmer IceDragonArt Kismet2012 Novica RGcincy Saphirewild Stormlyght xmasrose
DAZ Water Pump/Grain Silo (Prop- Water Pump) barbult Kismet2012 nonesuch00 Novica RGcincy xmasrose
dForce Dragon Wraith Skeleton/ Accessories (Prop-Dragon) IceDragonArt Kismet2012 Stormlyght
Drafting Tools (Prop- T Square) barbult IceDragonArt Kismet2012 nonesuch00 Novica RGcincy xmasrose
Dream Home: Great Room Accessories (Prop: Bench)
3dcheapskate dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita Novica RGcincy xmasrose
Dream Home Great Room Breakfast Nook (Prop: Chair W Arms)
3dcheapskate barbult dreamfarmer IceDragonArt kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild xmasrose
Dystopian Console Station (Prop-the Station)
3dcheapskate barbult dreamfarmer IceDragonArt kismet2012 nonesuch00 Novica RGcincy Saphirewild xmasrose
PROPS E- J
Epic Wings (Prop- Wings)
barbult dreamfarmer IceDragonArt kismet2012 nonesuch00 Novica Stormlyght xmasrose
Everyday Groceries (Prop- Toilet Paper) barbult dreamfarmer kismet2012 Novica RGcincy Wonderland
Everyday Stationary (Prop: diary open/closed) barbult xmasrose Novica
Fairy Wishing Well (Prop-Wishing Well)
barbult dreamfarmer IceDragonArt LaPetiteVerita nonesuch00 Novica RGcincy
Fantastical Sprite Wings (Gen8M/F) (Prop) dreamfarmer IceDragonArt kismet2012 Novica Stormlyght Wonderland
Fantasy Scythes (Prop: Classic Farmer's Scythe) nonesuch00
Fantasy Warship (Prop- The Warship) IceDragonArt Novica
Feathered Wings For All (Prop-Wings) dreamfarmer IceDragonArt kismet2012 Novica Stormlyght xmasrose
Fitness Pole Dance Poses/Prop Gen2F (Prop-Pole) LaPetiteVerita Novica
Fluttery Wings (Gen2F) (Prop-Dragonfly) IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica Stormlyght
Formula 1 Race Car (Prop- Car) dreamfarmer IceDragonArt Kismet2012 nonesuch00 Novica Saphirewild
Gladiator Weapons (Gen8F) (Prop-#1 Shield)
IceDragonArt kismet2012 LaPetiteVerita nonesuch00 Novica Saphirewild xmasrose
Grapevines (Prop- Grapes 2) Novica xmasrose
Geisha Prop Collection (Prop: 4 Asian Inspired Fans) jakiblue nonesuch00 Novica xmasrose
Golf Course Props (Prop: Golf Cart) Novica RGcincy
Gothic Bedroom (Prop: The Bed) IceDragonArt Novica
Halloween Jack O Lanterns (Prop-J.O.Lantern #1) dreamfarmer Novica
Hood Huntress Collection (Gen3F) (Prop-Bow & Arrow)
barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita Novica RGcincy Stormlyght xmasrose
Horse Drawn Carriage for Daz Horse 2 (Prop: Carriage) Novica
Haunted Toys (Prop: Scareybear) jakiblue kismet2012 Novica
Hybrid Trees Collection (Prop-Tree 7m 139K polys trunk) dreamfarmer Novica xmasrose
Iray Alligator by AM (Character) IceDragonArt Novica
i13 Dreams of the Past (Prop: Centerpieces) dreamfarmer Novica RGcincy
Industrial Storage (Prop: Gas Cylinder) dreamfarmer Novica RGcincy xmasrose
Inflatable Boat (Prop: Outboard Motor) barbult Novica xmasrose
Iray Ghost Light 2 (Prop: Flashlight) dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita RGcincy Stormlyght
Iray Snow, Ice and Ash (Prop-Snow Rock)
Jackson's Field (Prop: FIngerpost Sign)
dreamfarmer IceDragonArt LaPetiteVerita Novica RGcincy Stormlyght xmasrose
Jacuzzi Deck (Prop: Deck Chair 1 Red Cushion)
Janitor Gear (Prop: Push Broom) barbult nonesuch00 Novica RGcincy xmasrose
Jeweled Excellence Earrings 2 (G2/3/8F) (Prop: Earring) LaPetiteVerita Novica Wonderland Stormlyght
Jump Your Way (Prop-Full Gate #4)
3dcheapskate barbult dreamfarmer Kismet2012 LaPetiteVerita Novica RGcincy Stormlyght xmasrose
Props K - P
Kick Scooter (Prop: The Scooter)
barbult dreamfarmer IceDragonArt jakiblue kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy xmasrose
Lemonade Stand (Prop: Lemonade Stand) barbult jakiblue kismet2012 Novica RGcincy xmasrose
Laser Toss Arcade Game (Prop) IceDragonArt Kismet2012 LaPetiteVerita Novica xmasrose
Laundry Day Mega Set (Prop: Empty Dryer) barbult dreamfarmer kismet2012 Novica RGcincy
Magma-960 Quad Missle Launcher (Prop-Launcher) IceDragonArt Kismet2012 LaPetiteVerita Novica RGcincy
Make A Wish Props (Prop: Scepter) barbult IceDragonArt kismet2012 nonesuch00 Novica Saphirewild Stormlyght
Medieval Hall and Garden (Prop-Barrel on Stand)
dreamfarmer IceDragonArt LaPetiteVerita nonesuch00 Novica RGcincy Stormlyght xmasrose
Midnight Skeleton (Prop) IceDragonArt kismet2012
Moon Broom (Prop: Broom)
barbult dreamfarmer IceDragonArt kismet2012 LaPetiteVerita nonesuch00 RGcincy Saphirewild xmasrose
Monster Skulls HD (Prop: Cyclops Skull)
barbult dreamfarmer IceDragonArt jakiblue kismet2012 nonesuch00 Novica xmasrose
Morphable Meershaum (Prop-Pipe)
3dcheapskate barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy
Mortuorum Sacris (Prop: Coffin Lid)
3dcheapskate barbult IceDragonArt jakiblue kismet2012 Novica RGcincy Stormlyght xmasrose
Muelsfell Elven Monolith Modular Set (Prop: Monolith) RGcincy Wonderland
Multiletter System (Prop- Letter X Stand.Font) Novica Stormlyght
New Colony Props (Prop: Module 3e) dreamfarmer IceDragonArt Novica RGcincy
Nocturnal Fae Wings (GenM/F) (Prop:Wings) IceDragonArt Kismet2012
Pest Control Props (Prop- Mouse Trap Brass Old) Novica
Piercing Collection (Gen8F) (Prop-Nose Piercing) Kismet2012 RGcincy
Pillows (Prop-Pillow)
3dcheapskate barbult IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild xmasrose
Playtime (Prop-Hobby Horse)
3dcheapskate barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy xmasrose
Porta Potty (Prop) barbult kismet2012 Novica RGcincy
Poseable Peonies (Prop: Bush Double 2) dreamfarmer Novica Stormlyght
Primordial Barbarian Clothing (Prop-hand and feet wraps) nonesuch00 Novica
Props Pack: Fun In The Sun (Prop: Lounge Chair)
3dcheapskate dreamfarmer IceDragonArt kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild xmasrose
Props Pack Morphing Grassy Outcropping (Prop)
3dcheapskate dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild xmasrose
Public Toilet (Prop: Diaper Changing Station) Kismet2012
Public Indoor Pool (Prop: Lifesaver) dreamfarmer LaPetiteVerita Novica RGcincy
Public Pool (Prop: Lifesaver) LaPetiteVerita Novica
Props R- S
There are no "O" props.
Regenerator (Prop- Regenerator) 3dcheapskate barbult IceDragonArt Novica
RW Butterfly WIngs (Gen3F) (Prop) dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita Novica RGcincy
RW Ivy Swing (Prop #3 Swing)
Stormlyght xmasrose
RW Letters And More (Prop- Letter Q)
barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild Stormlyght xmasrose
RW Rafting Fun (Prop-Raft)
Sakura Ultimate Tree (Prop- Tree) Wonderland
School Craft Supplies (Prop- Paints/New Brush)
barbult dreamfarmer IceDragonArt kismet2012 LaPetiteVerita nonesuch00 Novica xmasrose
Sci-fi Antenna (Prop-Antenna) dreamfarmer IceDragonArt Novica
Sci Fi Hand Gadgets 2 (Gen2,3,8F) (Prop-Regenerator) dreamfarmer IceDragonArt Novica RGcincy Stormlyght
Scrappy The Robot (Prop) Kismet2012 LaPetiteVerita nonesuch00 Novica
Senior Citizen Props (Prop-Walker) Kismet2012 Novica
Signs of Protest (Prop- Protest Sign Left Hand) barbult Novica RGcincy
Slide3D Graces of the RIng Prop/Poses G3/G8 (Prop-Ring) LaPetiteVerita
Spinning Wheel (Prop-Spinning Wheel)
dreamfarmer IceDragonArt Kismet2012 nonesuch00 Novica RGcincy xmasrose
Stargazer Props (Prop-Telescope)
barbult barbult LaPetiteVerita dreamfarmer IceDragonArt Kismet2012 nonesuch00 Novica RGcincy Stormlyght xmasrose
Steam Bike Pro (Prop: Stack of Luggage)
3dcheapskate barbult dreamfarmer IceDragonArt jakiblue kismet2012 nonesuch00 Novica RGcincy Saphirewild xmasrose
SteamPunk Vents (Prop- Gears) dreamfarmer Novica RGcincy
Stellar Fury (Prop- Interstellar Killsat)
3dcheapskate barbult IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 RGcincy xmasrose
Summer Tree House Deluxe (Prop-WIndchime) LaPetiteVerita Novica
Sweet Temptation (Prop: Cake 1 W/Sauce) dreamfarmer Novica RGcincy xmasrose
Symphonic Sound Poses/Props G3F (Prop: Amp) Novica Stormlyght
SY Rigged Waterfalls Iray (Prop: Waterfall) barbult Novica Stormlyght
SY Super Splash Pack Iray (Prop-Ultra Splash) dreamfarmer Kismet2012 La PetiteVerita Novica Stormlyght
Props T- Z
Table Tennis (Prop- Bleachers) barbult Kismet2012 nonesuch00 Novica RGcincy Stormlyght xmasrose
Technophila Arcane: Star Scope (Prop: Scope)
3dcheapskate barbult dreamfarmer IceDragonArt kismet2012 nonesuch00 Novica xmasrose
Tele-phony (Prop-Rotary Dial Phone) kismet2012 Novica RGcincy xmasrose
The Gardeners Potting Shed Tools (Prop: Wheelbarrow)
barbult dreamfarmer IceDragonArt Kismet2012 nonesuch00 Novica RGcincy xmasrose
The Firearm Pack (Prop #2 Rifle)
Stormlyght xmasrose
The Werks Mega Prop Pack (Prop: Big Lollipop) xmasrose Novica
Thursdays Child- Deaddy Bear (Prop-Bear) 3dcheapskate Novica xmasrose
Urban Warrior (Prop- Large Sword)
3dcheapskate barbult kismet2012 nonesuch00 Novica RGcincy Stormlyght xmasrose
Vapor Pens and Hookah (Prop-Hookah/Pens) barbult IceDragonArt kismet2012 Novica RGcincy xmasrose
Vintage Boxing Accessories (Prop- Jump Rope OR Speed Bag) barbult nonesuch00 Novica xmasrose
Vintage Hotdog Cart (Prop-Hotdog Cart)
Vintage Luggage (Prop: Briefcase) barbult IceDragonArt jakiblue kismet2012 Novica RGcincy Stormlyght xmasrose
Vintage Tech (Prop- Vintage Voltmeter) barbult
Wave Breakers (Gen3M) (Prop-Surfboard) Novica Stormlyght
Wine Me (Prop: Corkscrew) Barbult kismet2012 Novica RGcincy xmasrose
Z Deadly Weapon Gun/Poses (G8/V8) (Prop: Silver Gun) Stormlyght
Z Skaters Props/Poses (Gen8 M/F) (Prop- SK Skateboard) barbult Novica
Sets A-E
A Curious Hallway (Set)
3dcheapskate barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita Novica RGcincy Saphirewild Stormlyght Xmasrose
Abandoned Gas Station (Set)
Aeridian Interstellar Throne Room (Set) IceDragonArt
aMAZEing Journey Around The World (Set) dreamfarmer IceDragonArt
Arches of the Past (Set) IceDragonArt
Asian River (Set) IceDragonArt Novica RGcincy
Bar Interior 2018 (Set) dreamfarmer LaPetiteVerita nonesuch00 Novica xmasrose
Bend of the River (Set) Kismet2012 Novica Stormlyght
Bradbury Suspended Rail System (Set) dreamfarmer Novica
Brianas Temple (Set) 3dcheapskate IceDragonArt Novica Saphirewild xmasrose
Cafe Luca (Set)
Chinese Courtyard (Set) IceDragonArt Novica Wonderland
Collective 3d Portraits Vignettes Old West 2 (Set) dreamfarmer IceDragonArt kismet2012 nonesuch00 Saphirewild xmasrose
Collective 3d Portrait Vignettes Old West 3 (Set)
dreamfarmer Kismet2012 nonesuch00 Novica RGcincy Saphirewild Wonderland
Collective 3d Portrait Vignettes Old West 5 (Set)
Containment Zone (Set) barbult dreamfarmer IceDragonArt kismet2012 Novica Stormlyght xmasrose
Crypta Sepultus (Set)
3dcheapskate barbult dreamfarmer IceDragonArt kismet2012 LaPetiteVerita nonesuch00 Novica Saphirewild Stormlyght
Crystal Dragon Lair (Set) Stormlyght
DA Palm Island (Set) IceDragonArt Novica RGcincy xmasrose
Dark Basement (Set) dreamfarmer Novicaa
DAZ Barn (Set) barbult kismet2012 nonesuch00 Novica RGcincy Stormlyght xmasrose
Disconsolation (Set)
3dcheapskate barbult dreamfarmer IceDragonArt kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild Stormlyght xmasrose
DM's Anardhaus (Set)
3dcheapskate Barbult dreamfarmer IceDragonArt jakiblue kismet2012 nonesuch00 Novica RGcincy xmasrose
DM's Cave of Secrets (Set) dreamfarmer IceDragonArt kismet2012 Novica Stormlyght
DMs Dark Shrine (Set) 3dcheapskate kismet2012 Novica RGcincy Wonderland xmasrose
DM's Memorial (Set)
DM's Serenity Court (Set) IceDragonArt LaPetiteVerita Novica Stormlyght
Dream Home Yard and Pool (Set)
Dungeon Hall (Set) IceDragonArt Novica
EArkham's ZWorld Highway Culverts (Set) IceDragonArt Novica RGcincy
Echoes of Andromeda (Set) 3dcheapskate IceDragonArt Novica xmasrose
Enchanted Ballroom (Set) barbult LaPetiteVerita Novica RGcincy Stormlyght
Sets F- R
Note, there are NO "H" sets. It's not a mistake.
Fancy A Game Of Chess (Set) Novica
Fantasy Tavern (Set) dreamfarmer IceDragonArt Novica RGcincy
Fantasy War Room (Set) IceDragonArt Kismet2012 LaPetite Verita Novica Stormlyght xmasrose
Forgotten Tunnel Entrance (Set) IceDragonArt jakiblue Novica xmasrose
Garden Escape Bridge (Set)
3dcheapskate barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild Stormlyght xmasrose
Generic Sci Fi Corridor (Set)
3dcheapskate barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild xmasrose
GIS Nova (Set)
3dcheapskate barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita nonesuch Novica RGcincy Saphirewild Stormlyght
i13 Foxy Lounge (Set) Novica
Industrial Storage Unit Interior (Set) LaPetiteVerita Novica
Jacuzzi Room (Set)
barbult dreamfarmer IceDragonArt jakiblue Kismet2012 nonesuch00 Novica RGcincy Saphirewild xmasrose
Medieval Castle Tower Interior (Set)
barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 RGcincy xmasrose
Mort Augur (Set) barbult IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 Novica Saphirewild Stormlyght
Mystical Cave (Set) RGcincy Stormlyght
Northern Terrace Street (Set) dreamfarmer IceDragonArt jakiblue nonesuch00 Novica RGcincy xmasrose
Old Country Farmhouse (Set)
Old West Bath House (Set)
barbult dreamfarmer IceDragonArt jakiblue kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild
Parkside Head Interior (Set) barbult dreamfarmer nonesuch Novica RGcincy
Patio Dining (Set)
barbult dreamfarmer IceDragonArt jakiblue kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Stormlyght
Picnic Area Exterior (Set) barbult dreamfarmer IceDragonArt jakiblue Kismet2012 nonesuch00 Novica xmasrose
Planet Glise (Set) IceDragonArt Novica
Planet Selena (Set) Wonderland
Reading Corner (Set)
barbult dreamfarmer IceDragonArt Kismet2012 LaPetiteVerita nonesuch00 RGcincy Stormlyght xmasrose
Romantic Pool (Set) dreamfarmer LaPetiteVerita Novica Wonderland
Sets S-Z
Sci-Fi Cockpit Interior (Set) dreamfarmer IceDragonArt Novica RGcincy Stormlyght
Sci-Fi Spaceship Bedroom (Set) Novica Wonderland
Shoot First Corner (Set) Barbult dreamfarmer jakiblue kismet2012 LaPetiteVerita Novica RGcincy xmasrose
Shroom Castle (Set) IceDragonArt Novica
Spooky Plots (Set) 3dcheapskate barbult Novica RGcincy
Summer Gazebo (Set)
3dcheapskate barbult dreamfarmer IceDragonArt jakiblue kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy xmasrose
Sun Hall (Set) dreamfarmer Kismet2012 Novica Stormlyght
Tangien Portico (Set) jakiblue Novica RGcincy xmasrose
The Alcove (Set)
3dcheapskate barbult IceDragonArt kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild Stormlyght xmasrose
The Backyard (Set)
barbult IceDragonArt kismet2012 nonesuch00 Novica RGcincy Saphirewild xmasrose
The Cage (Set)
The Ministry (Set) jakiblue Novica
The Daily Routine Office (Set) Novica RGcincy
The Void (Set) dreamfarmer Kismet2012 Novica Stormlyght
barbult IceDragonArt Kismet2012 nonesuch Novica RGcincy Stormlyght xmasrose
Trinity Atrium (Set)
3dcheapskate barbult dreamfarmer IceDragonArt kismet2012 LaPetiteVerita Novica RGcincy Stormlyght xmasrose
Velodome Track (Set)
barbult IceDragonArt kismet2012 LaPetiteVerita nonesuch00 Novica RGcincy Saphirewild xmasrose
Versatile Terrain (Set) jakiblue nonesuch00 RGcincy
Victorian Parlor (Set) dreamfarmer LaPetiteVerita Novica RGcincy Wonderland
Victorian Street Front (Set) barbult kismet2012 nonesuch00 Novica RGcincy xmasrose
Winterblack Tower (Set) barbult dreamfarmer Novica RGcincy Stormlyght
reserved
Reserved in case timeline needs more room and everything has to be moved down
Let the game begin! (Starts at 10:45, I am demonstrating to everyone how this works.)
Note in the Timeline, I will post who got Old Hagrad. (I posted her at 500 px high)
Oh RGcincy, someone wants to give you some love. You have 6 hours to pass her along, time is 10:45 p Central so 4:45am any game player can pounce and decide where she goes. First post AFTER 4:45am gets to decide.
Person: Kismet2012
NSF#5. Say Bye And Hi" Tell someone which product to give up to the list, and which one to take from it. The TYPE of item must be the same (a prop for a prop.)
Hey there, I just know you want to get rid of Make A Wish Props: Scepter (PROP)
So lucky you, you just got sent to the list and now own a Nose Piercing (PROP) from Piercing Collection.
Your character will look SO good with that. (You don't have to thank me.)
*Note the list has been changed. Piercing Collection is now in RED and not available unless taken from Kismet2012. The link at the top of that page takes you to this post.
*Note Kismet's possessions have been changed. ALWAYS CHECK THIS TO ENSURE THE LAST POST IS COVERED. Click the link at the top of that page- it's easy!
Hey nonesuch00
I know you've always dreamed of being boss. Now YOU get to tell who to be a thief, and what they're going to steal.
NSF#7 You're a Thief. Tell another person (your choice) they must steal a specific item (you choice) from another contestant. (your choice.)
Next- (and copy this in your post)
The person who had to steal MUST give up the same type item to the Now Available list, because now they have too many items in their possession. (If you made them steal a Character, they have to give up a Character.) It can't be the item they just stole. THEY get to decide.
The person who stole also tells the person they stole FROM, what item they must take from the list to replace it.
So the bottom line is, who are you going to tick off?
A surprise first move from the cheapskate's nemesis !
Person: 3dcheapskate
1. "I'll Swap With List" One time use during the entire game: Swap out one item with one from the list. The TYPE of item must be the same (a prop for a prop etc.)
Hi cheap, you remember that little "Overheating" joke of yours, when you did three renders of Andy (the Poser mannequin) in progressive stages of melting ?
And you remember that Andy said he'd get his revenge?
Well, he knows that you were planning on keeping that single use NSF#1 to get rid of the worst item in your possesion at the very last moment... not any more you aren't !
(Andy also happens to know that you don't really use any of the Genesises (Genisi?). Or DSON for Poser. And that you've almost forgotten how to use DAZ Studio! He thinks it's time to change that!)
So you have to ditch Warrior Maiden Tanwen (V4 CHARACTER)
And in her place take Yasuo For Lee 6 (CHARACTER)
Hope I did that right ? Edit:I assume that you'll update the list and current standing (since you mentioned that we don't need to use the templates now) ? Edit2: Added link to original image post.
Metadata: This is my first NSF (NSF1 once) and I haven't NSFed any other person yet.
Note: For this game, possessions which people start with can also be owned in the list because I didn't have time to highlight in red what people are starting with. If there are duplicates, I will note both people. Barbult also has Yasuo. (at least for now.)
