Postgre SQL
Please help;
I just installed Daz Studio 4.10 Pro...but i am getting these messages:
In my install manager i have the option to install 2 versions...but i dont know which of the two i have to install:
(i have windows 10 64 bit by the way)
1. PostgreSQL CMS (Win 64 bit)
2. PostgreSQL CMS from Valentina CMS conversion
3840 x 2160 - 423K
3840 x 2160 - 2M
Post edited by Chohole on
If you still have the Valentina one then you need option 2 If it is a completely new install then you need option 1.
You need 1 regardless, that's the actual database engine. If you haev an older installation, using Valentina and with a populated database, then "installing" 2 actually runs a conversion application that will make a postgreSQL database with the same contents as the Valentina database (if it can).
