V4 Morphs not working
I had a hard drive crash and have to reinstall V4 and all of her morph addons. None of them are working. When I double click them in Poser it looks like they're loading, but they never show up in the parameters tab. I've tried installing them in both PP2012 and PP2014. C/Users/Public/Public Documents/Poser Pro 2012 Content. I know the old installers had a box that would pop up after installation asking you to initialize the morphs. Could the new zips be the problem?
Any help would be appreciated.
I spent the day reinstalling M4 and morphs after my old files got corrupted. Yes, they need to be initialized and it seems the ones in the zips have to be done manually. Go to the !Daz subfolder in your Libraries folder, you should see something called DZCreateExPFiles.exe. Double click to run it, then do the same with the file called DZCreateExPFiles-V4.bat. This will initialize all your morphs and you should see them in Poser when you start it up again.
If you install with DIM they will be initialized, but if you install manually you need to run the initialization .bat (or .command) manually.
I tried the exe at first, but it didn't work so I tried the .bat file and that did it. Thank you both very much!!!
