Content Management Service Install Error
Porphyrogenitus
Greetings; I transferred over to a new computer, transferring programs.
On then new computer, I uninstalled DAZ (since the CMS did not transfer), and am trying to re-install.
Every time I attempt to install DAZ 4.6 I get the below error ("The installation of the DAZ content management service has encountered an error. You may need to contact customer support").
674 x 401 - 75K
Are you sure CMS didn't install at all the first time? See if it shows up under installed programs, and uninstall it. You could also make sure the installer is being run as Administrator. Another option is to install DAZ3D Install Manager, which will install CMS.
Thanks for the response:
I had looked there, and it wasn't at first. However now when I try re-installs (see below), it *does* show up, however it keeps giving the same error message when I install, and it does not actually seem to have installed correctly.That's odd -- in that screenshot there are arrowheads next to Products and Categories, which means the CMS is working.
Try using Window > Layout to switch to a different layout, and see if that fixes the menubar.
Thanks, that worked. I dk why it kept giving the error message.
THanks again and sorry to be so stewpid.
There are no stupid questions, unless you count some of the ones I asked when I first started.
Well my question-problems tend to be 1) ones that I troubleshoot for 4 hours without getting anywhere, 2) people in tech support wonder how I got that problem because they've never seen it before and 3) are ultimately solved by a click of a button only I didn't find it. :p
Thanks again for your help. ^_^
