Help with horse harness Please
TrishTrish Posts: 2,625
How do I lock this horse harness in place so I can move the horse and the harness stays with the horse?? Thanks in advance...Trish
905 x 569 - 288K
  • fixmypcmikefixmypcmike Posts: 19,612
    I'm assuming it's a conforming harness -- right-click on it and choose "Fit to", and select the Horse as the figure to fit it to.
  • TrishTrish Posts: 2,625
    When I do that it falls apart like this....Its the vintage sleigh harness and the mil. horse.....Trying to use it with the overland stage...unless you know of another harness that works better
    978 x 551 - 281K
  • NovicaNovica Posts: 23,905
    I'll surf some of the member's forum- I seem to recall that issue coming up before. If I find something I'll let you know. I know we were all discussing the reins and someone did a great job of getting fluidity into those. The harness may be the same principle :)
    edited August 2013
    From november 2006 in the old forums
    This is what I'm finding- the person says "these have harnesses that will fit that horse"
    Royal Carriages http://www.daz3d.com/i/shop/itemdetails/?item=2413
    Vintage Sleigh http://www.daz3d.com/i/shop/itemdetails/?item=3908 (which you have)
    also gave a link to http://www.3dxtra.net/ which shows a harness. Didn't read it though.
    That's all I can find doing a Google search
    Post edited by Novica on
    If you're using DS, try adding a Smoothing Modifier to the harness.
  • JaderailJaderail Posts: 0
    edited August 2013
    If that Is Horse 2 and not Mil Horse that could be the reason. I see only Mil Horse and some morphs supported in the INFO.
    Post edited by Jaderail on
    2 404's and 1 'not found'.
    Links to the store items from the archives are not valid anymore.
    Thanks.
    Thank you for trying to help with this I think I will try to download the free one at renderosity....maybe we can talk someone into making a new one???
  • edited December 1969
    This one at http://www.renderosity.com/mod/freestuff/details.php?item_id=64212 fits the Millennium horse fairly well, but has no reins. The harness from Royal Carriages won't conform for me and no matter what I do I can't make it fit...:sick:
  • viluvuluviluvulu Posts: 72
    Like fix-Mike said, try with smoothing.
    1. Right-click on it and choose “Fit to”,
    2. In your "Scene" tab, choose the object and click on the small arrow with 3 lines symbol. Then: Edit -> Geometry -> Apply smoothing modifier.
    3. In your "Parameters" tab. Go to mesh smoothing and play with the smoothing and collision sliders.
    Hope that helps!
    I wouldn't be able to use clothing without those settings!
