Easy Multiple Light Control
pnewhookpnewhook Posts: 70
Hey all,
I have a scene with a fair number of lights. The room for example has a series of eight spot lights in the ceiling shining down to fill the room.
Maybe I'm missing it but is there a way to gang all these lights together so one control can raise or lower the brightness? Right now I have to select each light individually and set them all the same. A pain when I want to keep adjusting the light brightness depending on what else is happening in the scene.
Thanks!
  • stem_athomestem_athome Posts: 518
    Hi,
    Select all the lights you want to change (you can place them all in a group if preferred), then "Edit-> Master Light".
  • pnewhookpnewhook Posts: 70
    That was easy - awesome! Thanks!
  • 0oseven0oseven Posts: 626
    edited August 2013
    deleted - duplicate advice !
    Post edited by 0oseven on
    Also, if you select all of them, you can simply control all of that stuff with all of them selected, if you want them all to be the same, that is.
