Hexagon scale factor
jothda
In DAZ Studio you can read under the OBJImportOptions that Hexagon uses "1 unit = 1 cm" as the scale for objects - but this is not true.
The truth is that Hexagon it is using "1 unit = 10 cm" - it least in the default settings.
If I save an obj file in Hexagon with an export scale factor of 10 then the scale is right in DAZ Studio.
And if I reimport it into Hexagon with an import scale factor of 0.1 it is working for Hexagon, too.
But I would really like to have the same scale in both programs.
Therefore: Is there any way to change the scale of hexagon to "1 unit = 1 cm".
Or is the DAZ Studio OBJImportOption for Hexagon simply a bug?
export .obj from D/S at Poser setting 1 unit = 8 ft [Scale is 0.410105%]
import into Hexie with 1 unit = 1 meter
export out of Hexie with 1 unit = 1 meter
import same .obj back into D/S using Poser settings 1 unit = 8 ft [Scale is 24384%]
It works, ain't broke, no fixie.
Thank you for your answer, the scaling between Hexagon and DS is working...
But I still find it not very convenient that the two programs use different dimensions in their scaling.
Maybe this is some kind of historical thing ;-).
Yup. Poser.
