Alias files for genesis2Female pose controll (solved)
kitakoredazkitakoredaz Posts: 3,526
DAZ seems change how to manage poze controlls of child nodes,
About gen2Female, there are many alias property (controller ) for each node .
eg head.expressions.
but these alias files are just assigend to the root node gen2F as poze controlls.
I do not know it is useful or not, but anyway daz decide so.
Now,,, poze controlls which we can tweak when select child node, seems all Alias files,
(eg Brow down, Mouth open etc)
then the actual poze controll.dsf are assgiend root node .
So that,, if I want to make original poze controll of head,
before I make ERC for controll which assigend head,
but now,, I may need to make poze controlls assigend root node, then make alias for head node
as same as daz default controllers?
then it is question,, that
I found the way to make alias files by manually edit dsf, it seems work without problems.
but it seems not so easy work. to set path correctly etc.
then Is there way to make and save Alias for another controller by ds tools?
I check new property editor, and new edit mode of parameters,
but I can not find the way to make and save alias files.,,,
I think I may missed something,, but there should be need option to make alias I think.
if there is no way at current,, I may request daz.
it is strange,, if there is no easy way to make alias files which das offere for controller.
there should be more clear regulation. without it,, some vendor use alias, but some vendor not use alias.
it make user confuse.
Post edited by kitakoredaz on
    OK,, Maybe,,,, ,I found option in Property editor, which can make "Alias" controller of which assigend another node.
    there is property cloner, (property editor option menu)
    I have not understand what "Property clone" means , I thought it would be simple copy of property,
    then I have not used the tool.
    but it can make Alias files with check Alias option.
    1. select the genesis2fem then open property editor,
    2 select poze controll which need to make Alias.
    eg now I select Pozecontrolles>Head>eyes>left eye close (PHMeyesClosedL etc)
    3 open property cloner by option menu of porperty editor
    4 select Target node,, I choose left eye
    It make Alias poze controlls as same name, same labell ,when I select left eye, in pozing tab.
    but there seems one problem.
    I think I can change only Alias labell and file name. (
    when I edit duf,,then make Alias , I can change "labell" of Arias.
    but after make alias by property editor,
    and I try to change Arias "labell" to clear understand,,,
    it change original poze controll labell too. it is not expected.
    after that property editor crush ^^; (in ds 4.6 beta)
    I may need to save the Alias once, then will try to change labell name ,, again.
