Can you adjust the backdrop?
I'm trying to add a backdrop that I think is slightly too large for the image, it still looks good overall but a bit stretched in the lower corners. Normally what I would do is to instead render the image as a png and add the background in photoshop but I always end up with ugly grey edges most notable around the hair and I don't seem to get that when just using a backdrop. So is there a way to adjust the size or position on backdrops?
  • FishtalesFishtales Posts: 6,148
    Either adjust the render size to the backdrop image pixel dimensions or resize the image to match the render pixel dimensions.
  • 3Diva3Diva Posts: 11,658
    I don't know if there is a way to adjust the backdrop in Daz Studio, but in Photoshop you can get rid of the grey edges by going to Layer >> Matting >> Remove Black Matte.
  • KitsumoKitsumo Posts: 1,216
    You could try the old fashioned method, create a plane in the background and apply a texture to it. You can also make the texture emisssive and adjust the brightness to where it looks realistic.
  • jkjjkj Posts: 23
    Yes. set image as backdrop, then click on image and select Layered Image Editor.
  • FirstBastionFirstBastion Posts: 7,804
    Applying the image to a plane will give you the most control over placement and size and stretching.
