Some 3D objects to render in Carrara
CelluloCellulo Posts: 60
edited August 2018 in Carrara Discussion
Lots of cool 3d models to render in Carrara or in other 3d software:
http://casual-effects.com/data/
http://www.3drender.com/challenges/
As the 3d objects from these links are not the carrara native format (*.car), in Carrara you need to use the "Import" menu from the "File" menu.
Post edited by Cellulo on
    on a side note for new users,
    the carrara object folder isn't for .obj files.  import the .obj then save to carrara object folders.
    keywd: newusertips
  • HeadwaxHeadwax Posts: 10,019
    -Thanks Cellulo
  • StezzaStezza Posts: 8,165
    yep... thanks for the links yes
