mcjTheLibrarian - Generate Low-Poly Bookcases Full of Book Props - 2022 update
mCasualmCasual Posts: 4,607
edited November 2022 in Freebies
All These Books Are Belong To You
November 2nd 2022 I added the missing page-pile-edges texture "pages.jpg" to the Low-Poly props zip package
( except the 1501st book of the Chromatographia )
it's 2 very low poly book props with width/height/depth morphs
plus a script to generate rows of books semi-randomly
 Generate Billions Of Books in Daz Studio https://sites.google.com/site/mcasualsdazscripts9/mcjthelibrarian
1080 x 1111 - 282K
1200 x 877 - 246K
648 x 960 - 164K
960 x 540 - 152K
1200 x 877 - 210K
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited September 2018
    more The Making Of pics
    960 x 720 - 195K
    960 x 726 - 125K
    1440 x 1080 - 267K
    1032 x 774 - 166K
    Post edited by Chohole on
    the randomly picked book covers are simply all the images residing in a folder of your chosing
    i made 55 , they are all 800x512,
    it's very easy to make your own
    1485×2115
    1485 x 2115 - 624K
  • Thank you very much, this will be very useful.
  • ImagoImago Posts: 5,246
    Boy! Do you read my mind? It's exactly what I needed for one of my projects!
    Thanks a lot! laugh
  • Thank you!  laughwink
    Note that the very IKEA'ish bookcases are here -->
    https://sites.google.com/site/mcasualsdazscripts5/mcjbookcases
    though you could also use this as bookcases
    https://sites.google.com/site/mcasualsdazscripts5/mcjslidewall04by10
    and for some bookcases with doors you could use this
    https://sites.google.com/site/mcasualsdazscripts6/mcjdecopanel
    many of my props have morphing channels so you can really adapt them
    not in the main index yet: https://sites.google.com/site/mcasualsdazscripts9/mcjminiarmoire
    960 x 540 - 135K
    960 x 720 - 185K
  • grinch2901grinch2901 Posts: 1,246
    This looks amazing. Thanks for this. Can't wait to try it out.
    1920 x 1440 - 3M
  • lukon100lukon100 Posts: 811
    Yahooo!
    I was the beta tester who found the absent pages image problem.
  • GreymomGreymom Posts: 1,117
    Wow - this is cool!  Many thanks!
  • perlkperlk Posts: 854
    Wow...these are awesome. I haven't played with this yet, can you stack them vertically, too? My brain is suddenly filled with Skyrim Apocrypha render ideas...
     if i remember well it creates individual books and horizontal stacks of books so you can move and rotate them
    there's a softcover poser/daz prop and a hardcover poser/prop which you can load 1 by one
    they are morphable props so you can resize them
  • And presumably a linear array bit of software could be used to instance the stacks and create a library so long as the stacks are repeated far enough apart not to see too many similar blocks in the same view. All without the need to sort a single book manually. That'd sound too good to be true to my wife - who works in a library and putting books onto the shelves is one of the annoyances of the job.
    Regards,
    Richard
     hi
    i didn't use it recently,
    today with 99 instances of a bookcase filled with books
    Daz Studio slows down a lot ( though in wireframe view mode it's workable )
    the books themselves are just 6-faces cubes
    that's the script i wrote to align them
    ( only works if the only object in the scene is the object that was instantiated )
    nodes = Scene.getNodeList()
    var master;
    n = nodes.length;
    list = new Array()
    for( i = 0; i < n; i++ )
    node = nodes[i];
    if( node.getObject() )
    master = node;
    break;
    node = nodes[i];
    if( !node.getObject() )
    if( node.getLabel().lower().indexOf( "book" ) >= 0 )
    list.push( node );
    debug( list.length );
    v = DzVec3( 0, 0, 100 );
    master.setWSPos( v );
    bb = master.getWSBoundingBox();
    master2 = list.pop()
    v2 = DzVec3( 0, 0, 75 );
    master2.setWSPos( v2 );
    ctl = master2.getYRotControl();
    ctl.setValue( 180 )
    for( i = 0; i < 25; i++ )
    master = list.pop();
    v.x += 94.6
    v2.x += 94.6
    master2 = list.pop();
    ctl.setValue( 180 )
    v = DzVec3( 0, 0, 250 );
    v2 = DzVec3( 0, 0, 225 );
    ctl.setValue( 180 )
    v.x += 94.6
    v2.x += 94.6
    Regards,
    Richard
    1280 x 900 - 630K
    Sweet - I'll try it out, thanks!!!
    @mCasual - is there a way to change the pages? The script cycles through the books folder but doesn't let you change out the page colors. Or if it does, I can't figure out how.
    Also, I get this error when I try to run it in DS:
    I installed all zips at https://sites.google.com/site/mcasualsdazscripts9/mcjthelibrarian?pli=1  into my Runtime folder in Content in the folder.
    1224 x 887 - 108K
    Post edited by perlk on
    I also realize you have an update to fix this but I can't find the low poly props script. I used https://drive.google.com/file/d/18PzTAVkCUik7XqxtsG8p-UmmlyE_Jav7/view?usp=drive_web but it did not fix the problem.
    Also - I just realized that even if I manually fix the pages.jpg file, it doesn't apply that texture anywhere.
    (FYI, I got around the problem by applying pages.jpg manually to all books in the surfaces page, and then re-loading the script and doing apply textures. So it isn't urgent for you to fix.)
    Despite my questions above, this is a really helpful script, thank you! I used it in https://www.deviantart.com/perlk/art/Apocrypha-937496704
    i'll look into it later today
    i didn't use it often after writing this script ( after creating it for one of my scenes )
    which must be placed according to your error message in Runtime/Textures/mcasual
    I attach it below.
    But I also see that there were other issues .. so ... this evening
    512 x 512 - 32K
    Thanks @mCasual
    I was able to do this render with your bookcases, so fun to create...
    2000 x 1125 - 4M
  • What? Only a few tens of thousands of books? Hardly enough to be worth it. ;) Regards, Richard.
    History
    November 18th 2022- I ( really ) added pages.jpg in the Runtime/Textures/mcasual folder in the new package filename: LowPolyBooksRuntimeWithPagesTexture.zip
    November 2nd 2022 - i added the missing texture 'pages.jpg' to the Low-Poly Books zip file and posted it in the attachments
    September 4th 2018 - Release
    512 x 512 - 32K
    perlk said:
    Thanks @mCasual
    History
    so with this missing texture it now works properly?
    image:The Surprised Librarian Anaglyph (red-left-eye)
    1440 x 1080 - 3M
    1440 x 1080 - 3M
    Thank you! I'll test it out in the next couple of days.
