UberSurface grey skin
I apply UberSurface shader and the model looks fine in preview, however, after i render the scene the model comes out in shades of grey. I read somewhere ctrl+click on the shader and choosing ignore should help. No dice. The model is grey with either replace or ignore. Any suggestions?
What Skin texture was on the Figure when you add the UBER to it? If you have a Link that would even help more.
I'm using Victoria 6 with stock texture. I believe its called V6 Belle.
That loads with the SSS shader applied at Default. Adding UBER on top of the SSS shader is the Error. I believe that texture comes with a SSS off version or a option to turn it off. Then you could use UBER. DAZ Studio does not allow two shaders at once at this time.
EDIT: No SSS off for it, I just checked My files.
Alright. Thanks for the quick replies.
So I have another dilemma. If I try to apply a different skin onto Victoria 6, like Norma, Elle, Nyssa, the figure also turns to shades of grey. And that's me not messing with any shaders or whatnot. I feel like i'm missing something here. Because even with the Belle skin there is an SSS option and a version without SSS now that I have looked at it closer. So whats the proper way to apply other skins without Victoria 6 turning gray?
