Simple Question about wiring bounding box
For some unknown reason (I must have changed something, of course) every time I select an object to manipulate it I see a lot of angled lines instead of the model. They disappear as soon as I release the model and once again I can see the original textures.
How can I reset this to keep seeing the model and not the block? Thanks.
Post edited by cesar_monroy on
http://www.daz3d.com/forums/discussion/27731/
just check , what I said in the topic.
You need to open tool setting tab, from Top menu windows>tab
then change During manipulation, drwa style l setting.
I do not know the linked OP can solve or not, and how solve,
but about your case, it will solve your problem.
Image removed for nudity. Please review this thread. http://www.daz3d.com/forums/discussion/3279_98/
Thank you, thank you THANK YOU!
I had installed and uninstalled DAZ3D Studio several times to see if I could restore the normal behaviour, but even after going to the REGEDIT to delete all entries, the wireframe keep pestering me. After Reading your post: PROBLEM SOLVED.
Thank you very much, again :)
