Trasfering V4 UV Mapps to G2F Genitals
timnaas
OK, I have being trying this with no luck at all. I have the Victoria 4 for Genesis 2 Female http://www.daz3d.com/new-releases/victoria-4-for-genesis-2-female but it doesn't seem to work with the g2f genitals. I can't seem to find a procedure in doing this or I missed it some where. Any info would be great of point me to someone that had done this.
Thanks
Convert the V4 Texture to duf format. Load the new Torso duf texture map on the Gens. That should be all that's needed.
Tried that, it doesn't work. The textures do not blend in. I does not line up properly and there is no way to "re-set" the UV's
Tried that, it doesn't work. The textures do not blend in. I does not line up properly and there is no way to "re-set" the UV'sAH!! Okay I did not know the G2F/V6 Gen's did not support the proper UV's. That is a issue. I never would have known as I do not do those type of renders very often any more.
Could you Send a Support Ticket and explain the ITEM does not support all the proper UV's it should? I'm not sure it is supposed to as V4 is a add on support but you can only ask and see.
