Has anyone ever seen this render error with the Toon Girls Shader?
I'm working with the Toon Girls Shader from Slosh.
http://www.daz3d.com/toon-girls-skin-pack
During the optimizing image phase of the render, I get this error message From my Daz Studio Log file:
Ran tdlmake on image F:/Daz Content/My Library/Runtime/textures/CrisPalomino/Genesis_Brow/GEM01alpha.png
ERROR: 3Delight Process exited abnormally: "C:/Program Files/DAZ 3D/DAZStudio4/bin/tdlmake.exe -mode periodic C:/Users/William/AppData/Roaming/DAZ 3D/Studio4/temp/d225.tif C:/Users/William/AppData/Roaming/DAZ 3D/Studio4/temp/d226_d225.tdl"
tdlmake: cannot open input file 'C:/Users/William/AppData/Roaming/DAZ 3D/Studio4/temp/d225.tif'
tdlmake: error while making texture file
There are a few of them that show up, and when it happens, the face texture turns solid black. I've turned off the bump, and added no other effects, though when this first happened I was trying to use some of the subsurface shader effects with one model, then I went back to doing it without and the error continued to pop up. I even cleared out the temp file before the next render, and it popped right back up. I exited out of the scene opened a new one and resurfaced the genesis 2 figure with the ToonGirls Texture and it popped back up.
System information from my log file.
+++++++++++++++ DAZ Studio 4.6.0.18 starting +++++++++++++++++
Platform bits: 64
Qt Version: 4.8.4
Running on Windows 7, Build 7601, Service Pack 1
CPU Information:
CPU String: GenuineIntel
CPU Brand String: Intel(R) Xeon(R) CPU E5-2620 0 @ 2.00GHz
Cache Line Size = 64
L2 Associativity = 6
Cache Size = 256
Stepping ID = 7
Model = 13
Family = 6
Extended model = 2
CLFLUSH cache line size = 64
APIC Physical ID = 32
Supported CPU Features:
SSE3 New Instructions
MONITOR/MWAIT
CPL Qualified Debug Store
Thermal Monitor 2
x87 FPU On Chip
Virtual-8086 Mode Enhancement
Debugging Extensions
Page Size Extensions
Time Stamp Counter
RDMSR and WRMSR Support
Physical Address Extensions
Machine Check Exception
CMPXCHG8B Instruction
APIC On Chip
SYSENTER and SYSEXIT
Memory Type Range Registers
PTE Global Bit
Machine Check Architecture
Conditional Move/Compare Instruction
Page Attribute Table
Page Size Extension
CFLUSH Extension
Debug Store
Thermal Monitor and Clock Ctrl
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Self Snoop
Hyper-threading Technology
Thermal Monitor
Pend. Brk. EN.
Physical Memory:
Total: 63.9 GB (68673552384)
Avail: 55.5 GB (59655000064)
Virtual Memory:
Total: 7.9 TB (8796092891136)
Avail: 7.9 TB (8795876515840)
Current Memory Usage: 13%
Current DateTime:
Loc: Tue Aug 27 22:39:43 2013
UTC: Wed Aug 28 02:39:43 2013
Temp Data:
Location = C:/Users/William/AppData/Roaming/DAZ 3D/Studio4/temp
Disk Total: 465.6 GB (500000878592)
Disk Avail: 214.6 GB (230437068800)
