pose helper animate for new carrara 8 pro64bit
cetmaccetmac Posts: 0
installed new carrara 8.5 pro 64bit via dim - pose helper "fenric" for carrara and animate for carrara although all functioning on older version of carrara now no longer visible/ accessible on new carrara 8 pro software. how do i get the animate and pose helper for carrara on to the new carrara 8 pro64bit
p.s native content was missing i manually added the folders within carrara browser
  • mmoirmmoir Posts: 821
    I was looking to get Fenric's "Pose Helper" and would like to know if you got it working in C8.5 . I am getting into animation and am interested in his plugins.
    Thanks
    Mike
  • FenricFenric Posts: 351
    Pose Helper works with 8.5, yes. What I can't really help with is the DIM - the extensions need to end up in the extensions folder, and I have seen quite a few threads complaining about DIM's relative ability to do so.
    You can try to unzip the zip file yourself and move the files manually - DIM isn't doing anything particularly special.
    Fenric,
    I don't use the DIM anyways so I should be good.
    Thanks
    Mike
