Noobie 101: How to duplicate objects in DAZ3D Studio 4?
cesar_monroycesar_monroy Posts: 17
Hi.
I have an object that I want to duplicate, but [CTRL-C] [CTRL-V] does not do the usual trick, nor selecting Copy/Paste from the menu. So, how can this mighty task can be accomplished?
Thanks.
    DAZ Studio does not have that function, but you can use Create > New Node Instance, which will produce an exact copy of the original. You can't change the texture on the copy, but you can change the size.
    What most people do, is save the item as a Scene, or Scene Subset, and then load it using Merge into any new scene.
