krill.MINIMA Cyborg for V4 - can it be loaded into Daz Studio 4.6???
Hi Newbie question.
I've purchased Daz Studio 4.6 and Carrera 8.5 Pro.
I am confused as to what content DS 4.6 can use?
In order to use krill.MINIMA Cyborg for V4, do I first need to install V4, and the (required product, Victoria 4.2 Morphs++) in DS4.6?? Does that even make sense? Or is it simply incompatible?
Or does DS4.6 automatically upgrade krill.Minima to work with the Genesis base?
Can someone explain to me how to navigate this issues in a general way?
What is compatible with DS4.6? And what is "importable"?
Thanks.
-dennis
  • frank0314frank0314 Posts: 14,298
    You need to install V4 and morph ++ into DS 4.6. If your installing manualy then you will need to install it to Documents\DAZ 3D\Studio\My Library. If your using DIM and the default folders then it would be installed into Documents\My DAZ 3D Library. Once they are installed you can find V4 in Poser Format/My Library or My DAZ 3D Library/Figures/DAZ People
  • edited December 1969
    Thank you. I'll do so now.
