General question about usage
XoechZXoechZ Posts: 1,102
Hello!
I am a DAZ Studio user and the longer I use it the more I am unsatisfied with the look of several clothes.
Now, If I buy Hexagon, can I simply load - for example - a skirt from DAZ Studio into Hexagon and make it longer, shorter, wider or tighter or whatever, and then use this version again in DAZ Studio?
If yes, is this easy or hard to learn?
I dont want to learn the whole modeling stuff, I just sometimes want to change some parts to fit my needs.
    There is a bridge between DS and Hex, so you could send your clothing item to Hex that way, make you adjustments to the item, and send it back to DS. When sent back, a pop-up window will ask if you want to create a morph, do that, save it, and you can use it again in another scene.
    Hex is not that difficult to get to grips with, but it doesn't work well on some systems, particularly Mac, but creating morphs for clothing is easy enough.
  • XoechZXoechZ Posts: 1,102
    Thanks for the answer. That sounds really easy and worth a try.
