Using Homo Erectus
RoygeeRoygee Posts: 2,247
Can someone please tell me how to get the Homom Erectus morphs loaded?
They don't seem to be normal mophs - all that happens when I inject is a brief flash at the top of the screen where it normally shows something being loaded, then nothing happens. I get the Poser mats to load onto M4, but that;s about it.
Is it actually a straight M4 morph, or is it a morph on maybe M4 Genesis?
Cheers :)
    Cheers :)
    The only Homo Erectus morphs that I could get to work were for V4.
  • araneldonaraneldon Posts: 712
    It's on my todo list to figure out why some morphs don't work in Carrara, there's probably a workaround that doesn't involve other programs. However I don't currently have any version of Carrara installed so it'll have to wait.
    I've wanted to see what the issue with the H-erectus morphs for M4 is for awhile, but I usually get sidetracked or have something else that I want to do more.
  • RoygeeRoygee Posts: 2,247
    Thanks, guys - some progress - at least I now know that it is a Gen4 morph and I'm not alone in my efforts :)
    EP, did you do any special/unusual steps to get it to work with V4?
    I followed a thread about it when it first came out. I followed the steps in the thread and immediately saved it to my Objects browser. I didn't bookmark the thread, but I know it was after the switch to the new forum software, so it should be around still.
  • kakmankakman Posts: 225
    edited September 2013
    For V4, the Homo Erectus Inject File (.pz2) is missing the quotation marks on the second line:
    readScript :Runtime:Libraries:Morphs:Mec4D:Homo Erectus V4:shev4.InjDeltas.pz2
    change the above to be:
    readScript ":Runtime:Libraries:Morphs:Mec4D:Homo Erectus V4:shev4.InjDeltas.pz2"
    Save the file.
    It will then work when you apply it to V4.
    The same change is needed for the Remove file as well.
    I have just tested this in C8.5 and it works.
    I have not checked yet, but I imagine the same correction is need for M4 and K4.
    Post edited by kakman on
    Remove duplicate post.
    Huh. I don't recall editing the file in a text editor. I'll have to go back and try injecting the V4 morphs again to try and jog my memory.
    Thanks for the info. I may be able to get the M4 version working because of your workaround. Thanks!
    Save the file.
    The Kids 4 files are already correct - no changes needed, I just checked using C8.5.
    The M4 file is quite different. It is trying to load several files by body part. I can not get that one to work and I am not sure what the problem is - yet.
  • ed3Ded3D Posts: 2,240
    _And in Carrara 7 Pro _seems also be this trouble
