Help - How do I use the smoothing brush for a morph across the bridge from Studio?
Diomede
I modeled simple skirt and blouse for G8F. Skirt ended up fine. Having trouble with the Blouse.
The blouse and skirt were modled to fit a custom morph and then the reverse to shape was used with the transfer utility. This caused some undesirable results around the breasts. I am trying to make a correction morph. I loaded the figure (blouse)in Daz Studio along with G8F, and then selected the blouse and sent it across the bridge to Hexagon. However, I can't seem to get the smoothing brush to work. I try, but nothing happens.
Any basic help for using the smoothing brush?
ps - the offending faces are not trianles, even though they look like it. that is what I am trying in part to smooth out.
1608 x 944 - 216K
1763 x 1043 - 267K
Post edited by Diomede on
That's not the smoothing brush. That's the subdivision tool. The smoothing brush is in the UV tab.
Ah, OK, thank you.
