How to clear/remove all "currently used" parameter changes to object and its' children
Wondering if this is possible;
Basically, I've adjusted limbs, hands, fingers, and want to "zero out" or remove all the changes I've made to them without totally resetting the figure to a predefined pose. If I could reset [everything below shoulder] for example that would be the best.
Is there a way to do this?
Thank you so very much.
  • Tramp GraphicsTramp Graphics Posts: 2,412
    Actually, it's pretty easy. Simply select the specific node(s) (if necessary, one at a time) and then go to the little box in the upper left hand corner of the Parameters tab, go to Zero> Zero Selected Items Pose (or Shape, depending upon what you want to zero out).
  • Richard HaseltineRichard Haseltine Posts: 102,130
    The zero commands are also in the Edit>Figure menu in recent builds of DS, if you have allowed the menus or layout to refresh.
  • stitlownstitlown Posts: 294
    It appears that the "zero" and "restore" commands only work on figures, not on non-figure items like props.  Is there a way to reset all parameters on a non-figure object.  ie the equivalent of "paramter tab / specific parameter / parameter settings / reset value" for all object parameters in one hit?
  • crosswindcrosswind Posts: 7,806
    edited January 6
    Use the action: Zero Selected Item(s)... which works on both of Props as well as selecte Figure's node (joint)...
    Create a shortcut or place the action on Toolbar...
    Post edited by crosswind on
    Brilliant, thanks Crosswind.
    No problem !
