Head injection
Vitor1Vitor1 Posts: 21
Dear sir,
I've made a head (and face) using Faceshop 8. Now i want to make an injection file to use it with other characters. I've already tryed with dsa file and duf file (shaping) and had no results. It only loads the face skin, the morph (obj) is not loaded. How can i load both the morph and the face skin files in a new character ?
Thanks
VM
  • Richard HaseltineRichard Haseltine Posts: 102,716
    For which figure?
  • Vitor1Vitor1 Posts: 21
    For Victoria 4.2 and/ or V4 Genesis 1
    Genesis is relatively easy - just go to File>Save as>Support Asset>Morph Asset, enter names for yourself as the author (or put Faceshop in) and give it a product name (these set the folder names used for the morph files) and make sure your imported morph is checked - the morph will then be available on all newly loaded copies of Genesis. Victoria 4 is trickier - if you have DAZ Studio 3 you could get teh free Morph tool plugins by Delta X and make an Inj/Rem pair for the morph using one of the spare channels built in to the CR2, but with DS4 you will have to use the ExP exporter plugin or hand-edit some files, neither of which is trivial (though the ExP Exporter isn't that bad).
