Bizarre timeline and object movements
![pward](https://secure.gravatar.com/avatar/e8c464df9db66348a3228628cc5baa99?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fe8c464df9db66348a3228628cc5baa99_100.png)
I apologize ahead of time...I'm a rookie who has been messing around with Bryce for a little bit. I have designed a few things and included some animations but I created a nice little spaceship and a rotating planet. Originally everything moved fine as the craft orbited the planet. But when I added additional details the timeline went berserk! Objects original to the craft and timeline as well as those added after began to separate in different directions from the path and the rest of the craft. It almost acted like it exploded.
I've deleted as much of the timeline and attempted to reset everything as much as possible but nothing is getting better.
OK...tried to upload but can't for some reason. If anyone is interested I can email it and see if anyone can fix it.
Cheers!
Patrick
Its been a long time since I've used Bryce, and nothing comes to mind on your problem. I haven't seen much about Bryce here in the animation Forum (although Administrator chohole uses Bryce I think, and shows up here occasionally). You might want to post your question in the Bryce Forum, if you haven't already.
I'll post over there ASAP! Thanks for the advice Steve!
Do I use Bryce Hmm does a bear c##p in the woods? :coolsmile:
