Assign category to file
rannar22rannar22 Posts: 6
I am trying to assign a set category to a spesifc file using a script.
unfortenetly so far i have only figured out how to read the categoris.
Post edited by rannar22 on
  • I assume you are aware of this sample, since you say you have managed to read categories. In any event, the DzAsset object http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/asset_dz has an addToCategories() method which shoudl be what you are looking for.
  • unforteently this is where i get stuck
    aAssets = oAssetMgr.findAssetsForFile(relPath, true, true);
    if(aAssets.length== 0){
    //i know i need to add addToCategories here
    //aAssets.addToCategories(catName);
  • aAssets is an array, so you need a loop to go through the array one asset at a time (if you start you loop at 0 and check that the current value is less than aAssets.length then it will not need the if you have as it will just loop 0 times). You then, for each one, use an array of categories  to add that asset to one or more categories -
    for ( var n = 0 ; n < aAssets.length ; n++ ) {	aAssets[ n ].addToCategories( [ catName ] ); }
    for example.
  • i am sorry i wasn't clear before.
    I am trying to add a category to a specific file (based on relative path)
    that file has no assets at all, so obviously the aAssets[ 0 ] will not be defined when i try to use it.
    edited December 2018
    You cannot categorise soemthing that is not an asset in the database - there'd be nothing to hang the category on. First you need to set the item as an asset, then you can categorise.
  • ok, and how can i do that?
