dsf files missing - strange looking figures
fablefan12fablefan12 Posts: 0
Hi guys
I'm new to Daz. Today I installed and thought I can work with it but all I get is this:
http://img4.fotos-hochladen.net/uploads/1q0oyndetu9.jpg
http://img4.fotos-hochladen.net/uploads/22xw319mydh.jpg
I don't understand this. Why are the dsf files missing?
I already looked for help on the internet but all the explanations are really confusing. Can you please explain to me what I should do? I can't work with those square things.
  • fablefan12fablefan12 Posts: 0
    I really need help guys.
    Change your display mode to texture shaded
    edited October 2013
    First, please don't "bump" you requests - they should get answered in due course, as long as the needed information is there.
    Now, the error is saying you are missing the files for the base Genesis figure so either you didn't download and install Genesis Starter Essentials or you did but the folder you installed to isn't set as a DAZ Studio content directory. The first thing to check is that you did in fact download and install the content - if you used the links in your Product History then look at the bottom of the DAZ Studio page for a number of separate packages you will probably want - certainly the two "essentials" and the SSS Shader.
  • slimacikslimacik Posts: 4
    i have the same problem.
    I tried to download these 2 files multiple times.
    371 x 149 - 10K
    1361 x 160 - 13K
    1325 x 75 - 8K
    I have tried to install it manually : without success
    449 x 362 - 31K
    CRC errors
    786 x 369 - 30K
    Unfortunately if the download is not completing there isn't much anyone else can do - all we can suggest is downloading, directly from your Product Library page since you presumably won't be able to install DIM on another system, and place the zip file in the downloads folder so that DIM can see and unpack it.
    Problem solved : i cleared History in Google Chrome....
