Question about DB_List_Products_Used and save in DS
TotteTotte Posts: 13,960
I have an interesting observation that I cannot figure out if it is a bug somewhere, or that this is "how it should work".
I've been looking and playing with Robs Sample Script DB_List_Products_Used
// Source: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/metadata/list_products_used/start
And it took me a while to realize that if you add products to a scene, the script nicely generate useful information, like:
{    "node": "Box2",    "products": {        "f70ac07a-1fd3-4ffc-aca9-ff5a1297b1a4": {            "title": "New Colony",            "files": [                "/Environments/Architecture/New colony/Materials/Iray/NC Box2.duf"            ]        }    }}{    "node": "Michael 8",    "products": {        "784cd38f-9da6-40e2-bd5f-2b0bef8a2208": {            "title": "Michael 8",            "files": [                "/People/Genesis 8 Male/Characters/Michael 8.duf"            ]        },        "5a680fc4-3284-4ba0-918e-d2f541e5827b": {            "title": "Michael 8 Pre-Release PA Build",            "files": [                "/People/Genesis 8 Male/Characters/Michael 8.duf"            ]        }    }}
But as soon as I hit save in DS, it comes out like this, or runs on an opened saved file:
{	"node": "Box2",	"products": {}}{	"node": "Michael 8",	"products": {}}
Is there something I can do ( I really want to expand this script, I have some very good ideas where to take it) to get that information "back", or is it lost as soon as the scene is saved?
Post edited by Totte on
  • Rob is working on an update to this script, so it may be worth waiting to see what that brings - it wouldn't really be productive to go back to adjust this version in the meantime.
  • TotteTotte Posts: 13,960
    Ah, thanks for the heads up!
    (and then the low flying dragon bit his head off)
    The update has now been posted.
    Thanks!
    Will take a look!
  • barbultbarbult Posts: 24,243
    I don't see any way to tell when a script sample has been updated. Is there any date or version info in them? Is there any change log for them some place?
  • In this case Rob flagged the thread to let me know.
    edited February 2019
    Is this a sign of a CMS in a state of slow  composting?
    I had to upload as PDF as the Cloudflare built in protection blocks you if you use SQL statements in a post
    pdf
    pdf
    pfdlog.pdf
    21K
  • Looks like it doesn't like the syntax, or it was passed an empty string.
    That was Robs new script ran unchanged on a scene with some items in. I ran it on a single item and it worked though. The scene with many items was a RRRR scene so it contains lot's of weird stuff.
    And the error comes from this part:
    		// Get the list of product GUIDs		var aGuids = getKeys( s_oProductsMap );		// Iterate over the list of GUIDs		for( var i = 0, nGuids = aGuids.length; i < nGuids; i += 1 ){			// Get the 'current' GUID			sGuid = aGuids[ i ];						// Get the product for the GUID			oProduct = oAssetMgr.findProductByGuid( sGuid );						// Initialize; capture the title			oProductInfo = { "title" : oProduct.title };						//If we are unifying the results			if( bUnified ){				// Capture the product GUID				oProductInfo[ "guid" ] = sGuid;			}						// Get the list of paths			aPaths = s_oProductsMap[ sGuid ];			// Sort and remove duplicates			aPaths = aPaths.sort().filter(				function( sValue, nIdx, aList ){					return !nIdx || sValue != aList[ nIdx - 1 ];				});						// Capture the paths			oProductInfo[ "files" ] = aPaths;						// Capture the product info			oProducts[ sGuid ] = oProductInfo;		}
