Folder Problem
![EddyMI3D](https://delorean.daz3d.com/forums/uploads/userpics/215/nF7CFA97FA528.jpg)
Hi, out there in the wide world
I just found out, that my C8.5P installation uses the shader and clip folders inside the C8P installation.
All other folders are used in the C8.5P installation.
When I installed C8.5P as new, I copied all Carrara Content (Scenes, Objects, Shaders, Presets, Extensions) from C8P to C8.5P, except they were newer in C8.5.
New Content is installed to the C8.5P installation by DIM and manually.
Is there a simple way to switch over the folders?
Thanks in advance,
Eddy
Post edited by EddyMI3D on
I found myself this solution:
I went to
Made a safety copy from Preferences.txt, opened Preferences.txt and made a patch exchange of the old folder names with the new ones, saved and closed and opened C8.5P
Now it ok again.
