Trying To Recreate iikuuk's old (2005) Poser 6 'Surface Imperfection Shader'
I'm referring of course to the screenshot of the shader in this old Renderosity post which I've reposted below:
I've just manually set up this Shader in PP2014, and I think I've made a mistake (or two, or three - most likely in connections or values) because it doesn't seem to work as intended. Here's a screenshot of my recreation (the dNdu node is there,but the material room moved it a couple of inches north of where it should be):
I recall reading somewhere that dNdu etc only work properly if you're using smoothing - i.e. 'Smoothing' ticked* in render settings and in the prop's parameter tab, and crease angle set high enough to prevent any creases.
So I tried using my attempt at the shader with a couple of props and SubD.
It doesn't work.
Can anybody see any mistakes in my recreation of the shader ?
The MT5 file that I created is in the attached ZIP (to save anybody who wants to help me and try it out from having to recreate everything from scratch):
