Re-naming folders in DS 4.6
obsessedwith3dobsessedwith3d Posts: 13
I'm new to DS, so I was wondering if you can re-name folders (within certain directories) to help organize my content?
Exp 1) Runtime\Libraries\Pose Could I create a V5 Poses folder and then move all V5 Poses to that folder?
Exp 2) Runtime\Libraries\Materials Could I make a folder called Bree and then move all of her loose files to that folder?
Thanks!
Kevin
  • fixmypcmikefixmypcmike Posts: 19,612
    Did you install the Poser Companion Files? Those directories are not for the DS versions of the Genesis items (although older items will show up under Runtime, as before Genesis most content was in Poser format).
    In answer to your question, I recommend using Categories to do your folder renaming. That way (1) you can't accidentally break something by moving the wrong file, and (2) if a product is updated you don't have to worry about tracking down the moved files.
