Collision
Any way to turn collision on between characters, objects and environments?
Signed,
The Total n00b
Signed,
The Total n00b
Yes. In the EDIT menu, Select the Geometry setting, for items select OBJECT and then do ADD SMOOTHING Modifier.
That turns on the Collision settings for the item. The settings can then be adjusted.
NOTE: DAZ Studio does not SUPPORT full physics. If items are NOT set up properly for the SLIGHT collision DS has they will still pass into each other. No walking into walls and expect the Wall to be solid. That is not built into DAZ Studio.
EXCELLENT, thank you! It's a steep learning curve, but once I get it down I'm sure it'll become second nature. Now I need a bigger screen. ;-)
Edit>Figure>Geometry.
