Evolution Head and Body Morphs Doesn't Work
I've installed evolution head and body morphs on DS4.5RC but it seems that it's not recognized by DS.
There are no dials, they were installed but no features were added.
I've been re-installing the morphs but still, no effect.
Is there a manual operation to make DS4 recognize that the morphs were installed?
Post edited by useless_1975_837db407db on
  • adamr001adamr001 Posts: 1,322
    There were a few products that when initially released for Genesis had some morph dials in the wrong place with a few other errors.
    If you look through your log file (View > Troubleshooting > Show Log File) and post the lines with the warning Duplicate Formulas found entries, I (and others) can help you sort out which products....
    The main ones were:
    Evolution Expressions
    Legacy Shapes V4 and M4
    But there were a few others that did it as well.
    These products need to be uninstalled (and/or the affected files as shown via the logfile manually removed) and then your download needs to be reset and the newer version installed.
  • edited December 1969
    I checked the log and I found 2: CTRLFlirtingMasculineL & CTRLFlirtingMasculineR.
    I deleted those two above and the error didn't appear anymore.
    On the side note, does DS4.5RC cannot be installed with Evolution Head and Body Morphs?
    Because I installed those two but I found nothing for their dials. The files installed were just in the right directory though.
    You need to delete the entire directory that those were in and reinstall the associated product. It's possible that there is a bug in the installer causing it to fail to find Genesis.duf if so that needs to be bug reported so it can be fixed properly.
  • edited June 2012
    I deleted the whole directory and reinstalled. Still the same.
    I don't know what is genesis.duf but I found a genesis.dsf here: DAZ 3D\Studio\My Library\data\DAZ 3D\Genesis\Base
    [EDIT]
    the evolution files were installed here in these directories:
    Studio\My Library\data\DAZ 3D\Genesis\Base\Morphs\DAZ 3D\Evolution
    Studio\My Library\data\DAZ 3D\Genesis\Base\Morphs\DAZ 3D\Head Morphs
    Did you reset the downloads and install those - reinstalling the original installer will give you the original files.
    Pardon me but, what do you mean by "reset" the downloads?
    Also, I reinstalled them like 3 times but no effect.
  • SzarkSzark Posts: 10,634
    edited June 2012
    "Resetting your downloads" means going to your account page here at Daz3D and going to "Itemized Oder History" then finding the offending itmes and hit the rest button and then go to the "My Downloadable Products" section of your account and "re-download" the items. Then reinstall the new morphs.
    This is presuming you purchased these morphs from the store here at DAZ3D
    But as noted uninstall the old ones first.
    Post edited by Szark on
  • JaderailJaderail Posts: 0
    Also Did not some of the older morphs get fixed to only show in Parameters and not in Shaping? Because of the bug Pro had? I'm not sure but I did read something along those lines once.
    Ah, Jaderail is right, look in the Parameters tab for them.
  • rbrekkenrbrekken Posts: 8
    Hi,
    I also have problems with Evolution Morphs not showing up in parameters tab. First of all, my system:
    Win7, DAZ 3D 4.5 with Genesis Starter Essentials, Genesis Evolution Body and Head Morphs and a lot of other stuff. everything installed using DIM. But I can not find the morphs any where in DAZ.
    If I use Victoria 4.2 character (also installed using DIM) I get a lot of morphs from the Morphs++ package
    I would like to figure this out before starting using DAZ 3D for real. I also had some problems with the morphs++ for V4.2, but it was caused by using an old installer. When installed from DIM it all worked perfectly. So now I install all from DAZ using DIM, but things from others are installed manually (from RDNA for example). Note that my content folder is not the default or public, and that is because I've run out of space on my system drive :-( I'm not an expert user, so I might have missed something essential...
    Thanks in advance... :-)
    Screenshots:
    V4.2 Working: http://dl.dropbox.com/u/29620/V4.2_Morphs_Working.jpg
    Genesis Not Working: http://dl.dropbox.com/u/29620/Genesis_Morphs_Not_Working.jpg
    Installation details Genesis Evolution Body Morphs:
    Content (D:/RBR/Documents/DAZ 3D/Studio/My Library) :
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLBreastsFlatten.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLBreastsHangForward.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLBreastsIn-Out.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLBreastsSide-Side.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLBreastsUp-Down.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLlBreastSide-Side.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLlBreastUp-Down.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLrBreastSide-Side.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLrBreastUp-Down.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLToesFanDownL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLToesFanDownR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLToesSmallCurlL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLToesSmallCurlR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLToesSpreadL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLToesSpreadR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMBodyBuilderDetails.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMBodybuilderDetails.png
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMBodyTone.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMBodyTone.png
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMEmaciated.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMEmaciated.png
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMFitness.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMFitness.png
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMFitnessDetails.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMFitnessDetails.png
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMVoluptuous.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMVoluptuous.png
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/MCMToesFanDownLeft01.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/MCMToesFanDownLeft02.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/MCMToesFanDownRight01.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/MCMToesFanDownRight02.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/MCMToesSmallCurlLeft01.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/MCMToesSmallCurlLeft02.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/MCMToesSmallCurlRight01.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/MCMToesSmallCurlRight02.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/MCMToesSpreadL01.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/MCMToesSpreadL02.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/MCMToesSpreadR01.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/MCMToesSpreadR02.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMAdamsApple.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMAreolaeDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMAreolaeDiameter.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMAreolaePerk.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMBreastsCleavage.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMBreastsHeavy.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMBreastsImplants.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMBreastsNatural.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMBreastsSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMBreastsSmall.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMCalvesFlex.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMCollarboneDetail.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMCostalAngleArched.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMCostalAnglePointed.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMFeetArch.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMFeetShoeFit.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMFootLengthL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMFootLengthR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMGluteCreaseL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMGluteCreaseR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMGlutesLowerDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMGlutesUpperDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMGlutesWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMHipBoneCrest.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMIliacLine.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMlBreastsFlatten.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMlBreastsHangForward.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMLegsLength.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMLineaAlbaDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMLoveHandles.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNailsLength.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNavelDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNavelHollow.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNavelHorizontal.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNavelOut.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNavelSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNavelVertical.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNipples.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNipplesDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNipplesDiameter.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNipplesVolume.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMPectoralsDeveloped.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMPectoralsVolume.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMPregnant.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMrBreastsFlatten.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMrBreastsHangForward.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMRectusOuterDetail.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMSacralDimples.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMScapulaDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMScapulaVolume.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMSternumDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMStomachDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMStomachLowerDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMThighsTone.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMWristThickness.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLArmsLength.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLChestDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLChestWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLFingersLengthL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLFingersLengthR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLFingersWidthL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLFingersWidthR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLNeckLength.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLPalmScaleL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLPalmScaleR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLShldrsScale.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLShldrsWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLTorsoLength.dsf
    Installation details Genesis Evolution Head Morphs:
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLTongue Curl.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLTongueIn-Out.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLTongueSide-Side.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLTongueUp-Down.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMBrowDefine.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMBrowDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMCheekBonesSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMCheekBonesWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMCheeksDefine.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMCheeksDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMCheeksDimpleCreaseL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMCheeksDimpleCreaseR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMCheeksSink.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMChinCleft.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMChinCrease.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMChinDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMChinWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMCraniumSlope.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMCrowsFeet.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEarlobesAttached.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEarlobesLength.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEarlobesSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEarsDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEarsElf.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEarsElfLong.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEarSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyeCorneaBulge.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyeIrisCorrection.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyeIrisSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelashesCurl.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelashesHideLayer.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelashesLength.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelashesTopPoint.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsBottomDefine.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsBottomInHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsBottomOutHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsFoldDown.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsHeavy.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsLowerHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsSmooth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsTopInHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsTopOutHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsUpperHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesAlmondInner.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesAlmondOuter.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesAngle.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesHeightInner.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesHeightOuter.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesPuffyLower.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesPuffyUpper.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesWrinkle.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFaceCenterDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFaceFlat.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFaceHeart.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFaceRound.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFaceSquare.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFaceYoung.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMForeheadDefine.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMForeheadFlat.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMForeheadRound.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMForeheadWrinkleL.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMForeheadWrinkleR.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMJawAngle.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMJawCornerWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMJawCurve.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMJawDefine.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMJawHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMJawLineDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMJawSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLacrimalsPinch.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLacrimalsSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLipLowerDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLipLowerSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLipLowerWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLipsDefineEdge.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLipsHeart.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLipsSquare.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLipsThin.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLipTopPeak.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLipUpperCurves.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLipUpperDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLipUpperSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMMouthCurves.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMMouthDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMMouthSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseBridgeDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseBridgeHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseBridgeSlope.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseBridgeWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseBump.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseFleshFull.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNosePinch.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseRidge.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseRidgeWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseRound.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseSeptumDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseSeptumHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseSeptumWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseSide-Side.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseTipDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseTipHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseTipWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseTwist.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNostrilsDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNostrilsFleshSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNostrilsHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNostrilsWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMPhiltrumAngle.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMPhiltrumDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMPhiltrumWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMPupilDialate.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMPupilSlit.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMTeethBottomSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMTeethCanineSharpBottom.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMTeethCanineSharpTop.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMTeethGap.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMTeethIrregular.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMTeethTopSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMTemplesDefine.dsf
    But you do have D:/RBR/Documents/DAZ 3D/Studio/My Library selected as a DAZ Studio content directory?
    edited March 2013
    Yes, of course :coolsmile:
    Screenshot: http://dl.dropbox.com/u/29620/DAZ_Content_folders.jpg
    Post edited by rbrekken on
    I'm answering myself... :-) Could this be the answer? Is morphs for Genesis in the Actor part of parameters?
    Screenshot:
    Morphs for Genesis
  • Tramp GraphicsTramp Graphics Posts: 2,411
    edited March 2013
    Screenshot:
    Morphs for Genesis
    Yep. They should also be found in the Shaping tab under your Smart Content when you have a figure selected.
    Post edited by Tramp Graphics on
  • Mari-AnneMari-Anne Posts: 363
    edited March 2013
    When I saw this thread, I decided to check my own body evolution morphs as I haven't used them since I reinstalled my content, using the DIM. And sure enough, I tested "Flirt" and it is not working. I have Genesis selected, and in the Parameters tab under Actor, I get nothing showing up.
    I double-checked and I did reinstall Genesis Evolution Head Morphs, Genesis Evolution Expressions and Genesis Evolution Body Morphs on 2/22/2013 with the Daz Install Manager. Why wouldn't it have completed the installation properly? All other content seems to have installed properly. Should I uninstall, reset and reinstall?
    Daz Studio 4.5.1.56 Pro - Win 8 64-bit
    Edited to add: I am noticing that only the Genesis Evolution Expressions seems to be affected. Body & Head Morphs are OK.
    2nd Edit: False alarm - all is well. Durn it anyhow, this always happens....
    Post edited by Mari-Anne on
    Hi,
    I've forgot to look for the expressions, and now I can't find them... Where are the supposed to be found in the UI? I've verified that the files are in place. Body and Head Morphs are working ok.
    If you look in the Parameters pane they should show when the head is selected.
    Thanks !! :-)
