Squares
marsbondmarsbond Posts: 22
I know posting her is not right, but i need help, i loaed DAZ3D once and all figures were loaded in squares.
    And you probably got an error message complaining about missing assets - if so, that means you haven't installed the needed content or its installed in the wrong place. Assuming you are getting an error alert, what does it say is missing and is that file on your system? If so, where?
  • marsbondmarsbond Posts: 22
    Installed The content through DAZ install manager, in the beginning everything was ok, then when i opened it last time, all figures are Square. :s
    Any error message?If not it may just be that you switched preview mode - assuming you haven't switched the viewport preferences click the sphere at top-right, between the camera/view list drop down and the option menu button, and make sure it'ss et to Texture Shaded.
    edited October 2013
    No error messages found. it looks like this:
    http://i40.tinypic.com/33dje3c.png
    Post edited by marsbond on
  • JaderailJaderail Posts: 0
    Your Viewport is set to block view, the Square in the corner, set that back to texture shaded.
  • RenpatsuRenpatsu Posts: 828
    Looks like Richard already picked that up correctly in his last reply, you are in "Solid Bounding Box" mode as for the preview, that is the box like icon right to the "Perspective View" switch, click that one and switch to "Texture Shaded".
    Missed that just checked the Render link... Richard is right of course.
    It worked out! thanks.
