Adding a morph to fix poke thru
![Sonofbelmont](https://secure.gravatar.com/avatar/84303e77a76fc1e6a395fa437a0ecc70?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F84303e77a76fc1e6a395fa437a0ecc70_100.png)
Hi
How do I go about adding a morph to fix the poke thru in some clothing?
I've got a dialled up Genesis shape wearing K4 basic wear Tankini and I'd just like to load on a morph that fixes some poke thru in the chest region. However creating a new target and then loading my obj doesn't work for the Actor morph area & creating a new morph area makes the clothing revert back to it's base shape. Adding a morph works fine for all the other areas just not Actor.
Any help would be appreciated
thanks
Post edited by Sonofbelmont on
You may just have to make sure that you are in the animation tab in the upper right rather than the modeling tab. Or, you may have to correct for genesis protecting the topology. In either case, the following two threads may be helpful. If they are not, provide a little more detail and someone with more experience will come along and clear it up.
Genesis specific thread
http://www.daz3d.com/forums/discussion/30432/
Poke through in general thread
http://www.daz3d.com/forums/discussion/29483/
Hope it helps
