Using background image for modeling
SpacelandSpaceland Posts: 132
HI all,
In Cinemad 4D or Moi 3D i can use background image to model so i can follow the curve of the object i am trying to replicate.
Is there away in Carrara to do the same or i need an object and put the texture on it?
I tried a search but seem i can't pin it down.
Thank you
    In the modeling room, half way down the panel on the right side of the screen, go to the "Global" tab.
    The very top of that tab is the Backdrop selections for three sides where you may load in your template images ;)
    You know... now that I know you're modeling - I want to see your work, right? ;)
  • SpacelandSpaceland Posts: 132
    Thank You.
    I did think it might be There but wasn't certain.
    yes you will see my work :)
