Can you turn off reflections in Collective3d Create a Room
I have Collective3d Create a Room Xpack 3, and it has the most amazing reflective windows. However, these are slowing down my renders and I'm wondering if there is a way to turn off this property? Thanks in advance for any help.
Post edited by ValKyrie_1856200 on
given that is Iray and photoreal (PBR) all you could try is lowering the Gloss Layer Weight so the reflection isn't as strong.
Thanks! Where do I find that? I used to be able to get right into the specular highlights and bump maps sections from within DS, but that was awhile ago and I can't find that stuff now. So much to learn!
I am presuimg you are using Iray but no matter the render engine all surfaces of an object are controlled in the Surfaces Pane.
