Is it possible to render a wireframe image?
Hello All
For some of my technical animation the "Wire Frame" view in the modeling room would be excellent.
Is it possible to render out a wireframe image?
Thanks
Brad
  • 0oseven0oseven Posts: 626
    Install Wireframe Pro from DCG Digital Carvers Guild - now available for free.   http://digitalcarversguild.com/
    The wireframe render includes the shader so make it glass [ something transparent ]if you are trying to emulate the model room..
    You will probably want all the plugins which will add lot more power to Carrara  -  cheers
  • StezzaStezza Posts: 8,164
    as @0oseven says.. grab the free DCG plugin and all your prayers will be answered... angel
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,369
    draft also will do it
  • Hello All
    Thanks
    Brad
    If you want the same look as in the model room, the easy way is to go to the UV tab, generate a UV map and use this UV map in the shader in the color or the alpha channel.
  • Thank you all!
