Welded vertices
BurpeeBurpee Posts: 152
How can I tell if all my lines and points are welded before I export an object? How do you know if there is a point or line that is not welded?
  • RoygeeRoygee Posts: 2,247
    Hit the "close" icon - if there are holes it will outline them in white. If you do need to weld verts, rather abort and weld manually than let close do it for you :)
  • BurpeeBurpee Posts: 152
    Thank you. Must admit I was hoping for a one push button solution but at least knowing that there are unwelded verts before export is a huge relief.
    We all do, but it doesn't work well so what Roygee said is the best way.
  • GhostmanGhostman Posts: 215
    Been looking for a Make Art button as well but never found it. :down:
